greglepore's Avatar
Wheel /tire fitment question
Well, I sorta kicking myself today. Bought a set of HRE wheels from a fellow Pelican yesterday. He was more than gracious, and the wheels were a total bargain-no problem there.
They were advertised as 8 and 9's by 17. Of course, neither of us put a tapemeasure to them, and it turns out they are 9x17 and 10x17.
If they were going on a racecar, I'd be gleeful, but they were intended for a street ride. The width difference give rise to 2 questions-
1) I hadn't planned on the expense of new tires as mine are relatively fresh-they're 215/45 and 245/40 Dunlop 8000's-I realize these are narrow for these rims, but can I get away with them for street use only until they're worn?
2)Is there any prayer of getting a 9 to fit on the front of a Carrera - the 7.5 that 's on there now has loads of clearance. I'd prefer not to muck with the fender lip. The seller tells me these were off an 89 Carrera, but ...
PS-I'm not at all upset with the seller; this was at best a mutual mistake and I picked the wheels up, so I coulda measured them. They were also priced so fairly that I might make money on the deal. Its just that I was counting on a low-effort swap, timing is bad for running around right now. If any of you track hounds ae interested in a swap for 8's and 9's, HRE or Fiske (or even converted Fuchs) send me an email.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 01-10-2004, 03:22 PM
Bill Verburg's Avatar
Why do you think that they are 9 & 10? Did you measure them? If so, from where to where?
Bill Verburg
Old 01-10-2004, 03:37 PM
Administrator
Jack Olsen's Avatar
Yeah, a set of 8x9 wheels will measure closer to 9x10 if you measure from outside edge to outside edge.
Old 01-10-2004, 03:50 PM
greglepore's Avatar
Outside edge to outside edge-I'll redo the measurement. Its odd, though, that its exactly 9x10.
Greg Lepore
85 Targa
Old 01-10-2004, 04:17 PM
Kevin Stewart's Avatar
you measure the inside edge to get the width, also 10's will not fit a narrow car with out reworking the oil lines, Kevin
Old 01-10-2004, 04:21 PM
greglepore's Avatar
Nevermind, I'm an idiot... They are exactly 8x9 inside to inside.
Greg Lepore
85 Targa
Old 01-10-2004, 04:22 PM
marcesq's Avatar
What offset are the 8s?? If they are not 23mm they probably won't fit the front unless you have flares.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 01-10-2004, 05:42 PM
Kinesis and Fikse measure out the same way. An 8 is 9" across and a 9 is 10" across.
Now we need the distance form the mounting face to the outer or inner face plane.
Lay a rigid piece of wood across one face and measure as accurately as you can to the mounting face.
Bill Verburg
Old 01-10-2004, 05:51 PM
greglepore's Avatar
Bill, the backspace is 140 mm to the face of the wheel, and the face to face is 230, so fronts are 25mm offset?
Rears, 143mm backspace, 260mm face to face width, so 13mm?
That sounds right?
Greg Lepore
85 Targa
Old 01-11-2004, 08:56 AM
marcesq's Avatar
Greg:
If those number are acurate (I don't know how to measure but I do know offsets) you should be ok with some negative camber up front and you might have to roll the lips . . . 215s might just fit though. My experience is with 205/55s, 205/50s and 225/45s up front.
Good Luck
Old 01-11-2004, 09:07 AM
Yes o/s comes out to be +25mm for the 8x17 and +13mm for the 9x17
Fit will depend on the tires chosen. 225/45x17 should be fairly easy to fit, lips and as marcesq said camber can be adjusted if necessarry, 235/45 etc will need commensurately more work. Mine are 235/45 on 8s w/ the same o/s, lips almost totally removed and normal street camber. For street use I hate track oriented camber settings.
At the back the wheel is 2mm closer to the oil lines and swing arm shoudn't be much, if any, of an issue. Again the tire chosen is key 255/40 or 265/40 should be fine, 275/40 only w a lot of extra work.
If you use 225/45 front then 255/40 rear is a good match, 235/40 & 265/35 is another nice setup.
Bill Verburg
Old 01-11-2004, 09:24 AM
greglepore's Avatar
Thanks for all the input and help. Bill, in reading a recent Excellence article on the Clubsport 964, one of the comments made regarded 225's degrading steering feel and effort. Is this overblown?
Greg Lepore
85 Targa
Old 01-11-2004, 09:56 AM
pjv911's Avatar
Send a message via AIM to pjv911
Heres a set of HRE`S on one of my cars. They are all 23.5mm offset with the fronts being 235/45/17 and the rears at 255/40/17 . The front rims are 8"x17 and the rears are 9"x17 . They fit perfect with all 4 fenders rolled. There is ample room on the rear inside (about 4") for oil cooler lines. Without the rolled lips I think the rears might have been too close. The fronts are close on the inside leaving about .080 clearance between the inner rim lip and the shocks steel protective dust shield. It could easily be removed however if it aint broke dont fix it. The car is being converted to erp billet coilovers at all 4 corners next month and that should open up a whole new can of worms for me. Im hoping for more clearance rather than less. BTW my car has standard front fenders and R/S flares (8") in the rear.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 01-11-2004, 10:11 AM
Different folks have different views. I don't know specifically about the 964s but for street use I am sure it doesn't matter. For tracking the 235/265 to 245/275 is certainly preferred. I guess it all comes down to how sensitive you are and how you like the chassis to feel. Chassis setup also affects this issue.
Are you setting up a race car, dual purpose or street only car?
Bill Verburg
Old 01-11-2004, 10:12 AM
Looking mighty tasty there Kurt!
Bill Verburg
Old 01-11-2004, 10:14 AM
greglepore's Avatar
Street for now. Really just wanted to lose a few lbs from the Mille Cup's that came with the car, and these wheels were too good of a deal to pass on. Probably overkill for street application, but at half the price of new Lindsey's, I couldn't pass on them.
I'm likely to be given a 944 when my 86 yr old Dad gives it up-this may be his last season with it, god love him. Thinking that might be the DE car for now.
Greg Lepore
85 Targa
Old 01-11-2004, 10:44 AM
For street use 225/45 and 255/40 are your easiest fitments and will perform fine.
If you get a chance I would love to get the weights of those wheels for my d-base. The other #s have already been added.
Still looking for the #s on a true 10x17 that anyone is successfully using on an SC/Carrera
Bill Verburg
Old 01-11-2004, 11:17 AM
greglepore's Avatar
The 8's are 22.5. I'll email you the weight of the rears as soon as I get the new inner and outer-the other has a tire mounted. Not as light as I had hoped. I believe these are model 340's.
Greg Lepore
85 Targa
Old 01-11-2004, 12:19 PM
pjv911's Avatar
Check this chart for wheel weights.
www.jimsnodgrass.com/wheels[1].html
Kurt Williams
Old 01-11-2004, 12:30 PM
pjv911's Avatar
Sorry link dont work
Old 01-11-2004, 12:34 PM
