-   -   I won the 930 trailing arms!!!!!!!!! (http://forums.pelicanparts.com/porsche-911-technical-forum/143330-i-won-930-trailing-arms.html)
MMe025 01-10-2004 03:17 PM
Well I finally won my 930 trailing arms withr rotors and calipers.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2452304895&category=33 564
I will be adapting my early 911 to accept theese trailing arms. What I need to know is? I bought a barely used set of 993 calipers with rotors etc... and I would prefer to use them. What would you brake experts reccomend? 993 on front and keep 930 calipers on back or is it even possible for me to mount the 993 calipers on the 930 arm? If I decide to use the 993 calipers how much should I ask for the 930 rear calipers with cross drilled rotors if I where to sell them? As you can see they seem to be in pretty good shape.
Matt
Bill Verburg 01-10-2004 03:36 PM
To use the 993 rear calipers on 930 trailing arrms you need to machine them to change them into radial mounts. The blleeds and feed will also need to be swapped.
Better to use the stock 930 calipers on the stock 930 rotors in the.
Best is to use matching 930 fronts on 930 rotors but, 993 fronts are ok if a bit on the aggressive side.
Raynald 01-10-2004 04:01 PM
Hello
i saw your last bid live ...
i am interest in your 930 calipers with rotors if it is for sale !!!
let me know...
Ray
