-   -   CIS Injector Cleaning? (http://forums.pelicanparts.com/porsche-911-technical-forum/143370-cis-injector-cleaning.html)
PHILIP315 01-10-2004 07:31 PM
I suspect it's got to be very diificult to tell if your CIS injectors have the optimum spray pattern, or which ones may have some buildup present. Of course, replacing them every 50K or so would probably be a great idea and improve perf., but that can be a bit costly! Does anyone know if the injectors can be cleaned? I don't mean the fuel additive cleaning, but removing them and soaking them in some type of appropriate solvent to remove all deposits??
Philip 75 911S
vash 01-10-2004 07:35 PM
do a search on this forum, there has been a bunch of chat about it. but on the contrary it is pretty easy to see if the spray pattern is good. you just pull them and get them to spray. you just missed some guy that posted his test here. it was last week (?). again another search.
vash 01-10-2004 07:37 PM
found it:
http://forums.pelicanparts.com/showthread.php?s=&threadid=142040&highlight=inject ors
vash 01-10-2004 07:49 PM
my only rust problem
here are some pics of my rust. i think the problem started along time ago when my stepdad refused to fix the front bumper rubber seal. is it tough to disassemble the front to check it out?http://forums.pelicanparts.com/uploa...1073792875.jpg http://forums.pelicanparts.com/uploa...1073792941.jpg
vash 01-10-2004 07:50 PM
damn ! my first pic post and i friggen stick it in the wrong area. sorry.
