-   -   Malfunctioning Turn Signals (http://forums.pelicanparts.com/porsche-911-technical-forum/143466-malfunctioning-turn-signals.html)
Zuff911 01-11-2004 02:02 PM
The turn signals on my 1973 911T work correctly only when the head lights or running lights are off. When I turn the head lights or the running lights on the signals will no longer flash, nor do I hear the clicking noise from the flasher. This problem was occuring before I replaced the turn signal stock, and flasher. Neither of which have solved my problem. Any suggestions would be great.
thanks
Brad
slakjaw 01-11-2004 02:18 PM
mine used to do this as well i cleaned the grounds that go from the tail lamp to the inner fenders and it fixed it.
give it a try
kyle
71` 911
RoninLB 01-11-2004 02:45 PM
sounds like a typical ground problem.. but it could be a harness connector problen
3.2 CAB 01-11-2004 02:50 PM
DITTO
vash 01-11-2004 04:45 PM
you know how all the wires (ok alot of the wires, not all of them) go through the headlight switch? how much do you think a new headlight switch will cost? i hate electical problems, so i tend to just change parts :) i would look into a new headlight switch, if it was inexpensive. keep us posted on this one please.
cliff
