Need photo of '69-'71 911S oil console
I am trying to an external oil cooler installed properly on my '69 911S. When I got it, it had nothing but the original hard lines remaining.
I got a front oil cooler kit from Chuck at Elephant.... and I found a factory oil filter / thermostat console used (at least I think its the correct thing).
On the '69 to 71 911S cars, the oil lines ran from inside the engine bay, through the rear fender, through the rocker panel and into the front fender well to the cooler. These hard lines I have in place. Inside the engine bay, the hard lines connected to a thermostat and oil filter console with lots of hoses and other parts attached.
I have never actually seen this assembly properly installed on a car. Anyone have some pics of what its all supposed to look like???
Thanks, any help figuring out how to get this thing installed and working properly is greatly appreciated!
Terry
Old 11-20-2003, 02:41 PM
Alan.UK's Avatar
Hi Terry,
I have this setup and also a spare S set in the loft. If no one else can help I will try and borrow a digital camera to show you but this will not be until next week. There are some pictures of my old car here, but I do not know how clear the ones of the oil lines are.
http://www.smartgroups.co.uk/pictures/openalbum.cfm?GID=1732050&AlbumID=2958825
HTH
Alan.UK
Always learning
Old 11-21-2003, 03:34 AM
Alan.UK's Avatar
Also Terry do you mind letting me knwo how much you paid for your 69-71 S set up and did it include the tank ?
Alan
Always learning
Old 11-21-2003, 03:40 AM
I paid $300 for the oil tank, filler neck, oil console and lines. The photos in your link do help, but I really need some close ups of inside the engine bay showing whever everything runs and how its all connected. If you can help, Id really apprecite it!
Anyone else got some photos ?
Terry
Old 11-21-2003, 06:19 AM
punt
Terry
Old 11-21-2003, 10:31 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Here is the oil consol from my 69S.
Hope it helps.
Bob
Bob Hutson
Old 11-21-2003, 03:12 PM
Yea Bob..... thats a start. Got any more? Can you show where the lines all run too? A couple more from some different angles would give a complete picture of how its supposed to look and fit.
THANKS!
Terry
Old 11-21-2003, 04:34 PM
maxnine11's Avatar
these diagrams may help a bit:
max
max
Old 11-21-2003, 04:54 PM
HawgRyder's Avatar
Max's diagrams show it best....the problem in the engine compartment is getting enough room to take a shot.
The air cleaner is in the way on the left of the shot and on the right, the body overhang is the problem.
It is my understanding that the 69's are alone in the design of the oil tank and filter and the lines feeding them.
Bob
Bob Hutson
Old 11-21-2003, 05:36 PM
Does part #59 attach to part #64?
Im guessing that 64 is the thermostat. Are there replacements for this thermostat available? Is there any way to tell if the one I have is no good?
The parts I have.... I am missing 65, 66 and the entire 62 assembly. Anyone have these parts or know where they could be had?
Thanks!
Terry
Terry
Old 11-21-2003, 06:34 PM
bump
Old 11-22-2003, 02:56 PM
HawgRyder's Avatar
I believe you are correct...#64 is the thermostat....
#66 is the line going to the front oil cooler.
#62 & @63 are the lines from the filter to the thermostat.
#65 is the line coming back from the cooler.
#53 is the filter holder of course...but it also has internal passages to send the oil to the thermostat and receive the bypassed oil back from the thermostat.
#54,55,56,57 are something to do with high pressure relief in the system if the oil cooler is blocked I think, or maybe to keep pressure from blowing the filter.
Bob
Bob Hutson
Old 11-22-2003, 03:15 PM
maxnine11's Avatar
here is a diagram and part numbers from the PET.
I think that the 'E' in front of some of the part numbers denotes that the part is 'NLA' from Porsche.
max
max
Old 11-22-2003, 03:24 PM
13 and 14 are the only 2 pieces I know I am missing at this point. Anyone have these lines? They dont look like they would be hard to replace. Seems you could have some braided steel lines made up to work fine if you knew what fittings to use and such.
Terry
Terry
Old 11-22-2003, 05:55 PM
HawgRyder's Avatar
Terry....the lines are part hard and part flexible.
I checked mine just now....I think the reason for the hard parts are so the turns don't kink.
If you use all flex...you should investigate the possibility of angled fittings to start the curves.
I was thinking of getting rid of all this stuff in my compartment to go with aftermarket thermostat and front cooler.
But I won't be tearing it apart for a while yet.
Bob
Bob Hutson
Old 11-22-2003, 06:04 PM
Zeke's Avatar
Mine.
Old 11-22-2003, 06:31 PM
Zeve,
Thanks for the pics! I do now know how it all mounts up.
All I need to install it now is Parts #13 and 14 in maxes diagram.
Anyone have these?
Terry
Terry
Old 11-23-2003, 05:38 PM
In the diagram that max posted above, I am still missing parts #6, #8, the flexible portion and the steel pipe that attaches to the oil console on part #13 and the flexible pipe portion of part #14.
The guy I bought this stuff from used assured me it was "complete". After 3 months and 2 attempts to ship me everything, its still not complete and I dont think it ever will be. Basically.... I got ripped for $300.
Anyone have any idea where these mystery parts could be obtained?
Terry
Terry
Old 01-11-2004, 05:52 PM
