-   -   Dreaded Tire Thread... (http://forums.pelicanparts.com/porsche-911-technical-forum/143516-dreaded-tire-thread.html)
Richard C2S 01-12-2004 09:21 AM
FWIW, I generally like the S0-3s on my SC on the street. I was a bit disappointed at the track. Under heavy braking at the end of a long straight, I felt that the fronts were squirmy. Maybe the sidewalls not stiff enough.
I'm actually moving the rears (225/50-16 on 7") to the front and putting 245/45-16s on 9" wide wheels on the back this week.
gerry100 01-12-2004 09:27 AM
I'm going to need new tires for my '86 also. Strictly for nice dry days and all the track time I can get.
Advice for newbies, buy a tire make/model that will be around when you need to replace the rears ( generally they wear at 2X rate of the fronts, maybe 3x if you drive real hard or track the car).
I got a great deal on Yoko AVI's from my mechanic, but after 8k miles ( approx 900 on track), the rears are down to the bars and the fronts are beautiful.
Since the AVI's are discontinued, I've got to buy 4.
Looking for recommendations.
steve911 01-12-2004 09:39 AM
Originally posted by masraum
S03's are good tires, or if you want to spend a little less money, get i little less stick, and have tires that wear a little better get the RE750's. I have them and had the prior RE730 and can vouch for them being good tires.
Steve-
did you ever have a noise issue with th 730's? Reason I ask, is that when I was planning on putting new tires on two years ago, I had ordered the 730's, but the TireRack guys called me and talked me out of them - said they were beginning to hear that the tires 'howled' after about 10,000 miles.
I went with the Kumho 712s and like them a lot, but would be interested in your experiences with both the 730 & 750.
FWIW, I have B'stone 950's on my Volvo 850 wagon and they're great.
no substitute 01-12-2004 10:06 AM
Ditto.
