toomany911s's Avatar
3.2 Carrera Motor into 73 MFI Coupe
I'd like some advice from someone who has already done this swap please.
I have an 87 3.2 Carrera(I've changed the flywheel) mated to a 915 Aluminium Trans and am ready to put it into my 73 coupe.
I have SSI heat exchangers and an sSS rear box, question I have is firstly what do I do about the heating, do I change the engine Tin, do I retain the blower assy on the 3.2? Also what exactly do I need to join the motor to my car, I have the 3.2 Fuel pump and coil, should there be a new fuel filter? what else should there be on the side of the engine bay where the spark box normally goes, I know that the Motronic brain goes under the seat inside the car but what else do I need????? What about the breather hoses???
Anyone help??
Anouska's Daddy 1995-2005 and Forevermore
Old 01-12-2004, 10:22 PM
I just put in 88 carrera motor with 915 LSD into my 74. I think I got all the bugs out. I used all 88 carrera items except that I located the fuel pump in the rear where my original 74 pump was located. I had to modify the 74 harness a bit to match the 88 engine harness. Since I am not going to use the rear defrost, I left out the rear electrical panel. You can come over or I can stop by. I am in Livermore.
-Steve
74 911S 3.2 GTS
74 914-6
Old 01-12-2004, 11:49 PM
Fantastic Steve, really appreciate it, It'd be great to come over and have a look.
Can you send me a number so that we can arrange a good time.
Ian
Old 01-13-2004, 06:42 AM
You can reach me at 925-321-0143.
-Steve
74 911S 3.2 GTS
74 914-6
Old 01-13-2004, 10:03 AM
addictionMS's Avatar
check out my website, I have the wiring harnes info there for a 1970, shold be very close..Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 01-13-2004, 10:24 AM
Actually, I used your wiring print out to help me clarify the Haynes wiring diagram. Thanks Jim.
-Steve
74 911S 3.2 GTS
74 914-6
Old 01-13-2004, 05:46 PM
Hi Jim,
thanks for your help, just what I need
Best Regards
Ian
Old 01-13-2004, 06:19 PM
