fallingat120mph's Avatar
Buying new fuel pump - parts needed?
1986 911 with 205,000 miles...starting to get the 'humming' noises and this week it was very loud sporadically so buying this:
https://www.pelicanparts.com/More_Info/94460810204.htm?pn=944-608-102-04-M14&gclid=Cj0KCQiAgOefBhDgARIsAMhqXA7_AAZPBOWIkkajxKfd 1YVdpT980RT93W--g7NmkS71Oq4kWfFR784aAtsZEALw_wcB
After researching I am wondering if I need anything else but what's included for the install of the above pump? Copper washers, etc...?
Just installed new fuel filter, so good there.
So many variables can cause issues, I see after researching, but the weather has been cool, the tank has been full and I checked inside the tank, best I could (just removed fuel level sensor) and it is impressively clean and clear. I have the car up and doing other work so I am just going to buy new at this point. I am debating on draining the tank and checking the tank screen -but am hoping a visual from the sensor hole and seeing how clean everything was is enough...
So, just wanted to verify before I order that I don't need other bits for a proper install...
Thanks!
Erik
1986 911 Coupe
1986 911 Targa
Old 02-25-2023, 11:53 AM
I did mine last fall and didn’t need anything more than that pump (with check valve and crush washer) and another crush washer for the banjo fitting.
'80 SC Targa
Avondale, Chicago, IL
Old 02-25-2023, 07:43 PM
I have the same pump but mine didn't come with any crush washers for the banjo. have to either reuse the current ones and smooth them down or I bought new ones.
Old 02-25-2023, 08:02 PM
So, all you needed extra was the washer for the banjo fitting...correct?
1986 911 Coupe
1986 911 Targa
Old 02-25-2023, 08:31 PM
I read that some just reused the washers after sanding smooth.
Thanks!
Erik
1986 911 Coupe
1986 911 Targa
Old 02-25-2023, 08:32 PM
Correct, but I’m honestly not sure whether I rescued the old one or got a new one. I am certain that the only thing I ordered was the pump from Pelican, though. It’s good practice to not re-use crush washers but often it’s fine in practice.
'80 SC Targa
Old 02-26-2023, 07:40 AM
PCA Member since 1988
Just don't tighten those washers so much that you "crush" them. Then you can reuse them a few times. Also buy some common sizes and keep them in your kit. Either copper or aluminum work.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-26-2023, 11:59 PM
