kiesan's Avatar
have to replace rear window gasket?
The rear window on my Carerra coupe leaks a tad on the passenger side. I'm going to have the glass R&R'd... can/should the gasket be re-used? It still seems quite pliable with no rips or tears so I was inclined to have the glass shop put it back all cleaned up with fresh sealant. TIA
Kie in Seattle. '05 3.4 987, '76 930 DP/Kremer thing. Past p's... '91 928S4, '95 993, '82 928, '91 944S2, '92 964, '67 912/911 2.7, '72 911/3.0, '89 951, '87 951, '94 968 cab, '96 993, '87 928S4, '78 911SC targa, '79 911SC, '84 Carrera row, '75 911S, '85 Carrera targa, '84 930 RUF, '04 996 C4S.
Old 01-14-2004, 12:32 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
For the peace of mind, it's worth the 65 bucks to replace it. Also, I believe there is no need for sealant. The seal is locked with the trim piece.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 01-14-2004, 01:08 PM
Now in 993 land ...
aigel's Avatar
The reason your window leaks is the fact that your rubber is old. There is no sealant necessary on a proper install. It is a window gasket, just like an O-ring, doesn't need extra sealant! All I found in my window channels was a spoon full of putty in the corners, possibly to center the window.
G
81 SC (sold)
Old 01-14-2004, 09:42 PM
Yep..
That's centering the glass in the frame.
I'd like to know the clearance.. or
Hey Kiesan.. do you know what the distance is from
the gasket edge to the edge of the chanel X 4
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-14-2004, 09:49 PM
Without a doubt get a new seal and have it R&R'd.
I just had the glass put back in my car and very glad I had a pro do it. They charged $35 for doing the rear window and he/they worked their behinds off getting the trim straight and the defroster wires hooked up. It looks great and is fairly inexpensive to have it done right.
BTW, I bought the seal and took it in to them.
Fritz
1987 944S
1973 911E
Old 01-15-2004, 10:22 AM
Harlan Chinn's Avatar
Get a new seal as the old one is probably dried up causing your leak and will probably need to be cut out. Be careful when cutting it out that you don't cut through the defrost wires that run around the rubber. They exit on the drivers side in either 2 or 4 places depending on whether you have a 1 or 2 stage defroster. Also be careful not to nick the paint with the cutting. If you do be sure to prime and paint over the nick as rust will form there. Also address any other rust areas if you find them when the glass is out.
Harlan Chinn
Pacific Northwest Region
1998 Carrera S ArcticSilverMetallic
1982 911SC PazificBlauMetallic
Old 01-15-2004, 11:09 AM
Now in 993 land ...
aigel's Avatar
One can use a sharp kitchen knife and cut from the glass side, parallel to the glass right on top of the glass. The trim and inner rubber rim will fall right out. Chances to cut the wiring or touch the paint are zilch that way. It works real well on old rubber, I can tell you!
To the folks that paid $35 to have it installed. Those poor installers didn't make much on that deal! It takes more than half an hour to do this right, even for a pro. I would think that they weren't knowing what they'd gotten themselves inot. I recommend doing it yourself or have a porsche shop do it.
George
81 SC (sold)
Old 01-15-2004, 08:19 PM
