vash's Avatar
i need a plan. oil leak
my car runs great. but i have a friggen oil leak. no surprise, but i think the majority is coming from the stud near the intermediate shaft for the oil pump. to dark right now for positive confirmation. but i know the stud is loose, i started to tighten it before, but i chickened out when i felt it click. i know my 2.7 is prone to this. should i back it out a bit to get some sorta sealent in there for more drive time before i gotta drop the motor and take it apart? the block is wet with oil there, so the other alt for a leak would be a cylinder right? the oil return tube looks sound. i really dont mind tearing the motor apart. (except the $$) my main goal for messing with the CIS was to get it running so i can be confident the fuel injection system would start a new motor. the leak doesnt look that bad on my garage floor, but i bet the main leaking is with the motor running. whatchathink? i have read wayne's rebuild book multiple times, so maybe i am ready.
maybe my house doesnt need dual pane windows..ha!
cliff
poof! gone
Old 01-14-2004, 05:39 PM
vash's Avatar
back to top...
poof! gone
Old 01-14-2004, 07:58 PM
makaio's Avatar
Can you post a pic Cliff? I read your post a few times but I just can't picture the exact spot you're talking about.
Old 01-15-2004, 05:44 AM
How sure are you that it is not coming from the top of the motor via the pressure switch or vent, etc?
Old 01-15-2004, 07:00 AM
Senior Member
Superman's Avatar
I'm not sure I understand what stud you're looking at. One alternative might be to install a sealing nut, or an ordinary nut with sealant under it. This does not sound like the kind of thing I'd disassemble a motor to fix, unless I was just itchin' to rebuild the motor with all its "while I'm in there" danger.
Mocha 1978 911SC. "Coco"
Old 01-15-2004, 08:08 AM
vash's Avatar
here is a picture
let see if this works
poof! gone
Old 01-15-2004, 04:44 PM
You need to get rid of the spaces and brackets in the filename.
Audi B7 S4
Old 01-15-2004, 05:38 PM
vash's Avatar
let me try again
poof! gone
Old 01-15-2004, 06:49 PM
vash's Avatar
thanks victor.
i am actually thinking it is the seal between the two case halves leaking? i will look harder this weekend.
poof! gone
Old 01-15-2004, 06:50 PM
TedSlick's Avatar
In hunting down leaks, I got some oil dye from Kragen (about $17 for four doses), ran the car a good bit, then looked at it in the dark with a hand-held fluorescent lamp (the kind they use for checking hand stamps at night clubs, etc. AKA blacklight). I bought it from a smoke shop ('70's store) for $14. It showed up as a concentration of bright, dense yellow at the leaking points.
Can help minimize the guess work.
g/l
Old 01-15-2004, 09:00 PM
Friend of Warren
Damn that stud is pretty easy to get to with a paper towel. If it was me, if it is only weeping oil, I would just wipe it off every day or so and not worry about it.
Kurt V
Old 01-16-2004, 05:43 AM
That oil dye is an excellent idea. I've never thought of that. I'll have to remember that one.
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 01-16-2004, 07:06 AM
Halm's Avatar
If it is weeping from the case line, would something like JB Weld stop it?
'17 Cayenne
Old 01-16-2004, 07:16 AM
vash's Avatar
g/l
does the dye ruin the oil? that sounds like a plan. i can always use the black light on my velvet elvis poster. to bad i dont still have the velvet matador poster...haha
puff,puff, pass...
poof! gone
Old 01-16-2004, 08:26 AM
TedSlick's Avatar
Per the manufacturer's description (you'll see in the box), the dye does not compromise the oil at all. Also works in the transmission and a couple other systems.
The black lights are also available at lighting stores...in case you're allergic to incents or tye dye Sound groovy?
Old 01-16-2004, 09:12 AM
