Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
70 tach to 79 cdi?
Will the signal from a 79 cdi box work with a 70 tach? I have to pull the 4cyl tach from the 912e and put a 6cyl in. I've got a 70 911t tach on the shelf.
70's get the signal from the distributor, while the 79's get the signal from the cdi box.
Thanks!
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 01-22-2004, 12:43 PM
Early_S_Man's Avatar
Porsche Crest
John,
There is a chance it will work. Some early tachs do work, others ... not!
If you know the 911T tach is functional, a simple buffer circuit [$20 in parts] with a handful of components on a small Radio Shack breadboard should be all that is needed if the '70 tach doesn't read correctly with the SC CDI unit.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-22-2004, 02:11 PM
Cool
isn't that what either of the 2 MSD tach adapters do ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-22-2004, 02:21 PM
