-   -   Where do I put 5 pound halon extinguisher? (http://forums.pelicanparts.com/porsche-911-technical-forum/144189-where-do-i-put-5-pound-halon-extinguisher.html)
aigel 01-16-2004 12:17 AM
I got a good used 5 pound halon fire extinguisher that needs to be installed inside my car for DE / time trial!
It came with a transmission linkage cover already attached, but I am not happy with the way it feels. The extinguisher is heavy and I am unsure if the sheet metal of the cover would hold on to it in case of a severe incident. I'd rather not have the extinguisher come loose!
I also do not like the transmission cover because I'd have to rip into the carpet. I have so far done all the mods for DE so they are completely reversible.
Being a 5 pounder, It is too fat to put it in front of the seat.
Is there a company making brackets to put it on the harness bar portion of the roll bar? That seems to be the best location I can come up with...
Where else do people put these? Unfortunately the season hasn't begun and I can't steal ideas from other 911 racers!
Please let me know!
Cheers, George
Eric Coffey 01-16-2004 12:42 AM
You can get a 5lb extinguisher in front of the passenger seat if you use a BK mount. You might not be able to put the seat all the way forward, but it will fit (this is going off of a standard Amerex 5lb halon/halotron bottle size). ;)
aigel 01-16-2004 12:58 AM
Eric:
I have Sparco Torino seats with sparco sliders. Will that still fit?
What is BK?
THANKS!
George
Wil Ferch 01-16-2004 12:01 PM
How 'bout slung under and clamped onto the trunk's camber brace rod....but you need a camber brace.... :)
Combine with a lever to activate from inside the car....run tubing to dash, inside car and engine compartment ( 3 places).
---Wil Ferch
cary 01-16-2004 12:57 PM
Originally posted by aigel
Eric:
What is BK?
THANKS!
George
Fits under my Milanos' right between my legs.
BK ........BreyKrause............equipment mfg.
I made my own and painted it up real pretty.
aigel 01-16-2004 01:34 PM
IIRC, the rules ask this to be within reach in the cockpit.
Oh, Brey Krause, okay.
What does the bracket look like that you made. Does it use the seat bolts (double up) or is it separately welded or boltet to the seat rails?
So, nobody has a source for a roll bar mounted solution???
Thanks, George
cary 01-16-2004 02:34 PM
Lots of roll bar mounts.
Just go to all the safety & racing guys websites. They all have them.
Mine, if I remember I'll take a picture.
Eric Coffey 01-16-2004 02:34 PM
For reference, here is a BK mount (model 2016) with a 5lb Halotron bottle:
http://forums.pelicanparts.com/uploa...1074291949.jpg
If you can move your passenger seat back far enough that it doesn't "overhang" the front OEM seat rail bolts, then it should fit. If you need any exact measurements of the bracket, let me know.
SmileWavy
Superman 01-16-2004 02:41 PM
I mounted a thick plate of aluminum to the side of the tunnel, in front of the passenger seat (aside the console) using small bolts. Yes, they penetrate the carpet and tunnel, but if I removed them, you probably could not see the holes. To this aluminum plate, I bolted the extinguisher's regular mount. It all fits.
aigel 01-16-2004 06:10 PM
I ordered the Brey Krause mount for non power seat, PN 2015 from EBS today. Should be here soon and no CA tax. ;) I hope it fits. One can fab something, but you can't beat a stainless tig welded rugged piece like that...
George
