-   -   CIS idle adjustment. (http://forums.pelicanparts.com/porsche-911-technical-forum/144229-cis-idle-adjustment.html)
vash 01-16-2004 09:29 AM
ok, i sorta understand how the idle is adjusted. with the air bypass screw. my book by Ben Watson, states that the idle is not to be adjusted by using that screw! he said it is a combination of procedures only to be performed by a qualified technician to get the correct idle. really? mine is a bit low at around 800 rpm. (when warm)
cliff
bb 01-16-2004 09:56 AM
I've adjusted mine with the screw and works just fine
Oscar
m325ix 01-16-2004 10:13 AM
Oscar
same here
Pat S 01-16-2004 02:40 PM
Are you sure? The book I have "How to Tune and Modify CIS" states not to adjust the idle by the throttle stop screw. It says TO us the bypass to adjust the idle speed.
In fact, to set the min air flow: It states you should turn the idle bypass in all the way and adjust the throttle stop down until the engine just barely idles (550 rpm). Then lock the throttle stop and adjust the bypass to get the idle back to 900.
Pat
fred cook 01-16-2004 02:42 PM
Idle adjustment.....
Once you are certain that the timing is set correctly, the valves are properly adjusted and the fuel injection mixture is ok, there should not be any problem with using the air bleed screw for small idle adjustments. Just don't use it as a crutch to fix or cover up other problems.
Fred Cook
'80 911SC coupe
vash 01-16-2004 02:43 PM
aw crap. let me go back and re-read this thing. i am surprised i got through college with my reading comprehension skills. what book to you have? probst?
Superman 01-16-2004 02:49 PM
Throttle body bypass screw. Yep. Play with it all you like. No problem.
Think long and hard before messing with the throttle stop adjustment. Your car will probably never need it.
Examine the plastic bushings that are SUPPOSED to be on the shaft that is mounted in the throttle linkage plate attached to the motor approximately over the #3 cylinder. And examine whether your throttle linkage is actually bringing your throttle to the fully open position. Very possibly it is not. If not, an adjustment will get you a little more power at full throttle.
vash 01-16-2004 03:05 PM
thanks guys
Pat S 01-16-2004 06:43 PM
I'm using this one:
Pelican Part# BK-116816AP
http://www.pelicanparts.com/catalog/...une_modify.JPG
Might be the same one you have. If it is see the Adjusting minimum air paragraph that starts on page 111.
I think it is a great book! The only part it doesn't cover is the decel valve. It gives very good explinations of everything else.
Pat
