SC Door maintenance and speakers.
I order a new door stay and the re-enforcer today as I'm going to do a little door maintenance pretty soon.
I thought I'd put new speakers in at the same time and clean up the window regulators.
Any parts I should replace while I'm in there?
And what's a good speaker that will fit the stock grills? Or
should I upgrade the grills to get a little more speaker?
Old 01-23-2004, 07:41 PM
Gordo2's Avatar
No Answer
Sorry, no answer but seeing that I have the same project planned this winter would appreciate your feedback as you work through the project.
Mine also needs reg adjustment for window height (currently too high to get a good seal).
I plan to go with some 5&1/2 to 6" speakers. From a quick search of prior posts it appears you should be able to fit a good pair.
Thanks, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 01-23-2004, 08:19 PM
walt's Avatar
If your interior door pulls are the original plastic and showing some age, you may want to consider replacing them.
Walt
82SC 3.0
81SC 3.6
Old 01-23-2004, 08:21 PM
I Did the aluminum door handles already. I did get new plastic clips were the rod fastens to the handle.
I guess I'll just have at it and see what I need when I get in there.
Old 01-23-2004, 08:29 PM
Send a message via AIM to fintstone
I replaced the plastic door liners (very thick, die-cut plastic sheeting material) between door and fiberboard door panels. Well worth the $6 to protect the expensive door panels.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 01-23-2004, 09:18 PM
Randy Webb's Avatar
Look around very carefully rust and treat it.
Consider spraying a micro-bead type (light wt.) sound deadener inside the panel.
Old 01-23-2004, 09:44 PM
Cool
consider a piece of sound deadner on skin
check if you have the up-graded regulator pivot
check lower outer skin to frame joint for rust
replace or clean interior of el window sw
hand slam inner sheetmetal to check for rattles
6 1/2" + 75w X 2 = dynamite
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-23-2004, 09:50 PM
What did you use for this? TIA.
'80 SC
Old 01-23-2004, 10:01 PM
Is there a brand name for this product? Thanks.
'80 SC
Old 01-23-2004, 10:02 PM
I got them precut from Appbiz...cheap! Wayne is starting to carry some Appbiz stuff, and maybe these..I am not sure.
Old 01-23-2004, 10:18 PM
geof33's Avatar
Man... blow the whole door panel and go RS!!!! Super clean, REALLY light, good for at LEAST 50 extra horses... "dyno proven" and look sharp too...
GruppeB #935
84 Carrera Targa B.A.S.T.A.R.D. (for sale)
82 SC RSR Project (on ebay)
95 Dodge Ram 2500
03 Toyota 4runner
Old 01-23-2004, 11:23 PM
I knew I could count on you guy's. This is the kinda while your in there stuff I'm looking for.
And those RS panels Look So Sweeeet, But if I did that were would my simple door maintenance project end? And I did get a gleam in my eye while looking at them.
I can hear my wife now, I thought you were just fixing the doors? Why are you taking the whole interior out??
Hmmmm, Did you say 50 HP? Sounds reasonable
Old 01-24-2004, 01:34 AM
I would lube all the moving parts of the door mechanisum while in there. It makes a world of difference
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 01-24-2004, 06:16 AM
Inspect the door handle triggers for elongation or tearing at the pivot hole.
'80 SC
Old 01-24-2004, 10:00 AM
geof33's Avatar
Here is what happens when you take a perfectly good, stock car and add RS door panels...
From this:
To This... in just a few thousand dollars
Check out that hottie in the first picture... At least it's not some bimbo with big T...ts.
GruppeB #935
95 Dodge Ram 2500
03 Toyota 4runner
Old 01-24-2004, 12:20 PM
Formerly bb80sc
Vipergrün's Avatar
Hey Bob, easy answer on the speakers, the best speaker is no speaker Did you pickup those SSI's? How bout a Sport muffler for a nice symphony of tunes?
Do they make those door panels in a tan? Very sharp looking and would go well with my weight reduction and spartan look I am shooting for. Oh yeah, they would go well with the car too....doh!
-B
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 01-24-2004, 12:31 PM
87turbolook911's Avatar
6.5 inch speakers will drop in easily, just need to remove the platic baffle inside the door to increase mounting depth.
It's not just the cars...It's the people...
Porsche Club of America
NoVa / DC / MD Porschephiles
Porsche911FactoryTurbo-LookCars
Old 01-24-2004, 12:45 PM
Randy Webb's Avatar
RS door panels are an appearance item -- and a fad. They save almost no wt. at all -- weigh them and find out. You save a small amt. if you delete the map pockets but it is inconsequential.
If you want to save wt. there are a lot of other things to do. First, avoid a bumper car, second avoid a targa. Next, start putting late Al suspension pieces on an early car, and then remove big sheet metal parts in favor of CF. See Jim Calzia's web page.
Old 01-24-2004, 01:13 PM
geof33's Avatar
Randy,
You just don't really get it do you? No, they aren't a fad, and they do save a little weight. Can you say tongue-in-cheek. They do look nice and very clean... if you don't like them... so be it
GruppeB #935
95 Dodge Ram 2500
03 Toyota 4runner
Old 01-24-2004, 06:51 PM
Hey' Randy
Lighten up , No pun intented.
Old 01-24-2004, 07:03 PM
