Super Moderator
cstreit's Avatar
'95 993 oil drain washer orientation
Can someone tell me how the washers under the oil-drain plug (for the tank) are oriented.
There are two washers apparently, one is thin and flat, the other is thicker and has a chamfer.
The car I just pulled them from has the thin one closest to the drain, and the thicker one over that with the chamfer facing "out". I would think the thin one should go farthest out.
Is this correct? The bolt is weeping some oil... Would copper washers to a better sealing job?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-17-2004, 01:40 PM
