Interior help, please.
I'll make this quick...
Getting ready to install a new carpet kit, but the driver's side screws for the rear seat hinge is giving me fits. It won't budge. My next step is to try and drill it out. I've never done this before and tips? Any RS carpet kit owners have this screw laying around that I could buy. Thanks fellas.
Marc 1971 T Targa |
Marc 1971 T Targa |
soak it in PB blaster overnight, then try the appropriate size socket-style bit on a ratchet (better leverage/torque).
What color is the RS kit that you put in a tan inerior?
after PB Blaster: try an impact driver or tap at the end of a large screwdriver wtih a hammer while turning or use a wrench on the screwdriver shaft for leverage.
Tru6 Restoration & Design |
Eric, thanks.
Milt, actually I was referring to the fact that this screw isn't needed if an RS kit is installed.
Marc 1971 T Targa |
Right tool for the job, Sears 4.95
http://www.pelicanparts.com/techarticles/911_interior_restoration/127.jpg
George My Owners Gallery Page 1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running. 1995 BMW 525I 2001 Highlander- kid mover |
Shaun, the thread is wider than any screwdrive they have at home depot, thus its worn pretty good. Thanks, though.
Marc 1971 T Targa |
George, whenever I'm back in NOVA, I'm going to find you and take you out to dinner!
Marc 1971 T Targa |
I'll hold you to that!
George My Owners Gallery Page 1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running. 1995 BMW 525I 2001 Highlander- kid mover Last edited by GB83SC; 01-17-2004 at 04:46 PM.. |
Boston,
Just removed mine last night using the wrench on the screwdriver shaft as suggested by Shaun.
1977 911S 2.7 GruppeB #036 |
Boston,
I reread your posts regarding the HD screwdrivers. The one I used from home depot did not fit the entire length of the screw head but it fit approx. 3/4 of it and otherwise fit the screw head and it worked just fine. Ive PM'd you. It feels good when you get those darn things out.
Thanks, Tim.
The thread is fairly shot, am going to need something wider. Maybe a wood chisel?
Marc 1971 T Targa |
If the chisel doesnt work, they make bits designed to back out stripped screws. They go for around $20-30 for the set. Have never tried them but understand that they work pretty well.
good luck
