CIS question
I posted before that I have an 82 SC track only car that was recently dyno'd running lean with an AFR of 14+ at WOT. I've identified that the dome lights and everything else on that circuit are not working. My question is does that mean the Lambda unit isn't getting power as well? If that is the case, would the fact that the frequency valve is not working cause it to run lean at WOT?
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 04-07-2007, 07:20 AM
Somatic Negative Optimist
Gunter's Avatar
The fuse for the dome light powers the relay for the Lambda brain under the pass. seat.
No fuse, no power. Replace fuse and wiring.
Check this: With engine running, pull the relay off the brain.
Notice engine running worse?
Use dielectric grease on the pins.
Also, you can reach behind and feel the Frequency Valve vibrating if it has power.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 04-07-2007, 08:17 AM
Thanks Gunter. So if the frequency valve insn't working, will it run lean at WOT?
Sean
NASA GTS2
Old 04-07-2007, 09:31 AM
where is the dome light fuse located?
1973 911T Slantnose
GSXR 600
1995 740I
1992 SC400
1992 E36(M3)
Old 04-07-2007, 03:16 PM
#18
Sean
NASA GTS2
Old 04-08-2007, 04:26 AM
Gunter's Avatar
If you are running Bosch K-Jetronic CIS with Lambda, the mixture is off without the Frequency Valve in all RPM's.
Did you replace the fuse? Did you pull the relay for the Lambda as described above? Notice a difference in idle? Do that first and let us know what you find.
(The Lambda brain is neglected and gets rusty, clean the pins and use dielectric grease)
Confirm that the FV is working, then I'll suggest what to do next.
You do not want to run lean in WOT.
Old 04-08-2007, 06:52 AM
I'll try this tomorrow. I've tried replacing the fuse before with no luck - it's not the fuse. I think i have an open circuit that I need to track down.
Sean
NASA GTS2
Old 04-08-2007, 07:23 AM
