-   -   Need help with tachometer (http://forums.pelicanparts.com/porsche-911-technical-forum/144655-need-help-tachometer.html)
scca_ita 01-19-2004 01:48 PM
I have a 74 tach and I was told that there is a separate piece (transducer?) that is located in the rear to the left of the engine.
I need this piece. The newer tachs (74plus) have this piece inside the tach.
I am trying to get the tach to work with a 3.6 Motor. other suggestions?
Lorenfb 01-19-2004 08:09 PM
Your old tach requires a high voltage signal from the coil and not from the DME
output. I don't remember ever seeing a tranducer on any early car. Just connect
the tach wire (purple/black) to coil side which goes to the ignition unit.
Early_S_Man 01-19-2004 08:34 PM
NO, no, no ... none of the 2.4 or 2.7 tachs required the ballast-resistor assembly mounted on the relay/fuse/regulator panel! It was phased out during 2.2 engine production.
As far as the 2.4/2.7 tachs go, some will work with the DME output, and some won't ... it is a matter of sensitivity. The Voltage 'swing' of a DME signal is not quite as great as the solid-ground signal from points ... and the 100 Ohm pullup resistor to +14 Volts.
Give the tach a try hooked directly up to the DME signal ... it won't hurt the tach, and it might work fine!
ischmitz 01-19-2004 09:26 PM
My 74 tach worked just fine with the 3.6 until I swapped everything for 964/993 gauges. Just give it a try. I am sure it'll work just fine.
http://forums.pelicanparts.com/uploa...1074576346.jpg
Ingo
scca_ita 01-19-2004 09:38 PM
I did try it briefly before I discovered my engine was crap and needed rebuilding, and it did not work.
When I sold the previous engine I gave the new owner everything on the panel next to the engine. So when the tach would not work I started to wonder if I gave away something I needed.
I also had some strange issues with the alternator light, When the key was in the off position the light stayed on. So I will be chasing this down too.
I did talk to Patrick Motorsports today, in their conversion harness they put a voltage amp to raise the signal out of the DME for the earlier tachs so I need to check this to make sure there is no issues with the soldier connections.
Early_S_Man 01-19-2004 09:54 PM
An IRF9630 or IRFD9123 HEXFET buffer ought to do the trick ...
Dr.Benzin 04-08-2007 06:23 AM
Sorry about my "english" guys !!!
Taco-Tachmeter- or what ever you call it, please try it in my langvitch: "turteller"
Thanks for all the advises !!!
