nylart's Avatar
Tie Rod Repair
I have an 84 911 with turbo tie rods. I just noticed that one of the rubber boots covering the ball joint has a tear in it. Pelican tells me they do not have a replacement for just the rubber. I was going to try to cover it with silicone but am wondering if anyone else has had this problem and how you solved it.
TIA,
Art
Old 01-20-2004, 10:26 AM
Jeff Alton's Avatar
I have just discovered this same problem. I am going to solve it by taking the car to the shop that installed them 9 months ago and have them replace them for free.
Jeff
www.turn3autosport.com
Old 01-20-2004, 11:52 AM
ditto. Have found no source on the boots. I;m going to replace the tie rod ends.
Old 01-20-2004, 12:07 PM
ditto. Have found no source on the boots. I'm going to replace the tie rod ends. That sure must've been a crap run of boots they did for awhile.
Old 01-20-2004, 12:08 PM
