cvfncrew's Avatar
Does any one have experience cutting painted fiberglass.?
I need to cut a 2nd opening on my rear fiberglass valence for my new dual muffler.
Any help would be great.
Christian
"YELLORS" 1972 911T with a 3.4l, PMO 46's
Vierte Tür Klub Member.
PCA National DE Instructor
Old 01-23-2004, 12:41 PM
Cool
if you have some experience with glass.. I would go easy to see what kind of lamination I'm dealing with.. then I would probably saw it short, then file to size..
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-23-2004, 01:26 PM
More Likeable IRL
juanbenae's Avatar
put tape around the edges of the cut that you want to save. back in my carpenter days if i was going to cut the bottom of a door i would put tape on the saved portion right at the cut line. kept the paint from chipping, and the wood from splintering/fraying. i would use a jig saw with a very fine metal blade.
Old 01-23-2004, 01:47 PM
Friend of Warren
I do it a bit different. I put masking tape over where I am going to cut, draw where I am going to cut, then use a dremel tool to make the cutout.
Kurt V
Old 01-23-2004, 01:54 PM
vash's Avatar
i saw i man working on a boat use Kurt V's method. he taped the area to be cut and just cut down the middle. but he used a jigsaw. i bet a rotozip would rock through it. by the way, the man had serious eye and respiratory protection on.
poof! gone
Old 01-23-2004, 01:57 PM
911ctS's Avatar
Send a message via Yahoo to 911ctS
thats exactly what i do as well. Use a cut-off disc on a dremel.
_____________________________
Clint Smith
www.RebelRacingProducts.com
1970 911T ----> RGruppe RS/R (mexico blue)
1995 993 becoming an RS (gran prix white)
Old 01-23-2004, 01:58 PM
Navin Johnson
TimT's Avatar
Mask the area, apply some heat to soften the paint a tad, then dremel, cut off wheel, fine jug saw etc. cut short and file to your line
'69 911 GT-5
'75 914 GT-3
and others
Old 01-23-2004, 02:02 PM
More Likeable IRL
juanbenae's Avatar
so i was right on the tape part?
Old 01-23-2004, 02:13 PM
cvfncrew's Avatar
Thanks guys.
My Dad and I will try it this weekend.
Old 01-23-2004, 02:17 PM
Zeke's Avatar
If you use a jig saw, buy a plunge blade that cuts on the push. Use the tape. If you don't fine the plunge, try cutting from the back so you are pulling thru the paint. Or just finsh with a file or drum sander on a drill.
Old 01-23-2004, 02:34 PM
When cutting my RSR front for lights, I tried the jigsaw, then switched to a die grinder. It created lots of dust (wear protection) but it was really accurate too.
Old 01-23-2004, 02:51 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Masking tape and Rotozip. Works on the boat too...
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 01-23-2004, 02:54 PM
MBruns for President
JeremyD's Avatar
I've done my share restoring boats and agree with dhoward 100% - Make sure it's good quality masking tape. Dremel works too - highest setting with a cut off disk (the large one)
Old 01-24-2004, 04:52 AM
3.2 CAB's Avatar
I tape, mark cut line on tape, cut through tape, with Dremel using carbide tool cutting burrs. Leaves very smooth line, they will also cut glass and steel the same way, either from edge or plunge cuts.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-24-2004, 05:05 AM
cvfncrew's Avatar
Thanks guys it worked..
Christian
Old 01-24-2004, 05:44 PM
Cool
for trivia,
I have a small 26p publication by the respected boatyard group called the Gougeon Brothers' "West System".
Called, Building, Restoration & Repair with Epoxy, #20, fall '02.
if you don't live in a boatyard area and want a scan, etc ..... Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-24-2004, 05:54 PM
JeremyD's Avatar
Originally posted by RoninLB
for trivia,
Ahhh the holy grail - West Systems - of course I've converted to FGCI - a local brand - West cooks too fast in the tropical heat - even with the tropical hardner!
Old 01-24-2004, 06:26 PM
