Por15 yet again..Is this a good deal?
I am going to use Por15 in my engine compartment, if I am going to spray it on would you use these guns?
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=90985 |
Friend of Warren
Can't get much cheaper than that. They will do the job if your compressor can support the CFM needs of the guns.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I use a older model of one of these.
http://www.1-home-improvement.com/power-sprayers/Campbell-Hausfeld-HV2000-B0000223PD.html It works very well
Ken Copeland 70 GT6+ KC78784 70 Spit FDU84919 70 GT6+ KC81551 (Ok so I like 70s) 71 Porsche 911T 00 Chevy Pick UP |
I wouldn't use a gravity feed. A touch up gun will be perfect. I'd set the gun at 60# and use a little of the Por thinner. You gotta have a good mask with new filters. I usually use a 2 sq ft window fan blowing the mist away from me.
I'd probably shoot 2 thin coats, then wait to 400 wet sand, then a final coat = beautiful
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Author of "101 Projects"
Cheap tools often leads to cheap results. You might want to check some out here:
http://www.pelicanparts.com/catalog/tools/DWKS-tools_autobody.htm -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
