scca_ita's Avatar
Por15 yet again..Is this a good deal?
I am going to use Por15 in my engine compartment, if I am going to spray it on would you use these guns?
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=90985
Old 01-21-2004, 05:13 PM
Friend of Warren
Can't get much cheaper than that. They will do the job if your compressor can support the CFM needs of the guns.
Kurt V
Old 01-21-2004, 06:34 PM
kcope's Avatar
I use a older model of one of these.
http://www.1-home-improvement.com/power-sprayers/Campbell-Hausfeld-HV2000-B0000223PD.html
It works very well
Ken Copeland
70 GT6+ KC78784
70 Spit FDU84919
70 GT6+ KC81551 (Ok so I like 70s)
71 Porsche 911T
00 Chevy Pick UP
Old 01-21-2004, 09:51 PM
Cool
I wouldn't use a gravity feed. A touch up gun will be perfect. I'd set the gun at 60# and use a little of the Por thinner. You gotta have a good mask with new filters. I usually use a 2 sq ft window fan blowing the mist away from me.
I'd probably shoot 2 thin coats, then wait to 400 wet sand, then a final coat = beautiful
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-21-2004, 09:59 PM
