| John Rogers |
01-22-2004 01:26 PM |
Weber 40IDS Problem Solved
If you remember the earlier post about the hi speed lean problem with my Weber carbs, well it has been solved. The small tab on three of the floats had depressions from the old needle valves wearing on them and when new needle valves were put in, this caused the floats to stick low so fuel level was way too far down. The shop rounded up 4 level gauges and watched the fuel level and it would drop some and then stay down. Putting in 3 new floats cured the problem and now the hi speed enrichment circuit gets enough gas! The wear marks can be seen if you look very carefully at the float tabs.
