-   -   Will a PPI detect broken head studs? (http://forums.pelicanparts.com/porsche-911-technical-forum/145245-will-ppi-detect-broken-head-studs.html)
FenderGuy 01-22-2004 08:41 PM
Just wondering if a PPI will detect broken head studs and if there is a valve job needed?
Vipergrün 01-22-2004 08:44 PM
I'd have the mechanic pull the valve covers and check the studs. A compression check and/or leak down could reveal possible valve issues, but there are other things, such as carbon buildup, which could skew the results.
-B
Por_sha911 01-22-2004 08:55 PM
When I bought my car last year I talked with 5-6 different dealers or mechanics. MOST PPIs are visual only. If you want to know if you need a valve job or have head stud problems, you'll have to pay extra for a leakdown test. Ask what the PPI covers and what the cost is to have a leakdown done at the same time (IMO its well worth it).
dtw 01-22-2004 09:01 PM
Just make sure to specify that you want compression and leakdown tests, and inspection of the head studs (requires removal of the valve covers). The going rate here is $150-175.
-dtw
DonDavis 01-22-2004 10:41 PM
I would ask a shop to provide a sort of "checklist" that you could expect to see. Or at least a breakdown of what they check and costs associated with the "extra" items you would want inspected.
