-   -   Halon alternative.... (http://forums.pelicanparts.com/porsche-911-technical-forum/145269-halon-alternative.html)
kees 01-23-2004 03:44 AM
I need to buy a new fire extinguisher. After a few searches through this BBS I see a preference for Halon.
But in the Netherlands, since january 2004, it's forbidden to use Halon.
What's the alternative?
Thanks,
SmileWavy
Kees.
Jack Olsen 01-23-2004 03:51 AM
http://www.firecharger.com/
(Per Pelicanite Makaio.)
350HP930 01-23-2004 04:38 AM
For fuel and oil fires you will certainly not want either a halon or CO2 gas estinguisher.
An ABC rated powder or foam estinguisher is where it is at. They may leave a mess behind but at least you will avoid having your car turn into a charred mess.
304065 01-23-2004 07:18 AM
AFFF. Aqueous Film Forming Foam. Environmentally safe, displaces liquids, tastes great over Muselix.
Plavan 01-23-2004 08:40 AM
I have the Firecharger (foam type) system on my race car. I hope I never can say "It works great" or worse, "The thing didn't work".
All kidding aside, the Firecharger would fit your needs if you have a full race car. It might look funny in a street car. That's not to say you could not put it in a street car.
http://www.plavanracing.com/photogallery/DSC00094.JPG
TRE Cup 01-23-2004 08:54 AM
We've become dealers for the AFFF Firecharger systems. cost is $449 for the 10 pound system and $349 for the 5 lb system. Either comes complete with bottle, mounting bracket, tubing, nozzles, and cable
turbo6bar 01-23-2004 09:09 AM
What size Firecharger do you need for the engine compartment alone?
Jürgen
Jack Olsen 01-23-2004 10:07 AM
On my Halon system, TRE put the tank in the front trunk, with the pull concealed behind the ash tray. Flip it down, and then handle's right there. Flip it back up, and it looks totally stock.
This picture shows the alternate ash tray I snap on for the track. It has the face removed, with the tray adapted to hold the Hot Lap display.
http://forums.pelicanparts.com/uploads/9HotlapTimer.jpg
Plavan 01-23-2004 11:10 AM
Jack- I would not consider your car a "street car" :)
scottb 01-23-2004 11:54 AM
Can you use Halotron ?
cstreit 01-23-2004 01:12 PM
AFFF. Halon can not even be shipped by many places now...
kees 01-23-2004 01:27 PM
Halotron is not available in the Netherlands.
I will go for the AFFF.
Thank you all.
http://www.pelicanparts.com/support/smileys/wat6.gif
Kees.
Peterfrans 01-23-2004 01:32 PM
Kees,
Why not opt for such a setup:
http://forums.pelicanparts.com/uploa...1074893532.jpg
kees 01-23-2004 02:12 PM
OEM Porsche fire extinguisher
http://forums.pelicanparts.com/uploa...1074895906.jpg
Kees.
TRE Cup 01-23-2004 04:00 PM
The five pound system is more than adequate for engine and interior, or engine- fuel cell, or just one zone. For the engine we include a second nozzle and T fitting so you can put one nozzle on each bank of the 6 cylinder motor
