Registered Loser
Why Tubular Steel?
I hope this isn't a totally dumb question. I noticed that a lot of GT race cars are made of tubular steel. But why don't they use tubular carbon fiber like high performance bicycles?
Owner of a wrecked 944
Old 01-23-2004, 10:58 AM
Senior Member
Leland Pate's Avatar
I always thought it was because CF tubing is only strong under certain types of loads. It seems like CF is weak when it comes to torsion... or was it compression. But is strong in other areas.
I dunno.
Chief Architect and Mastermind,
SCWDP
Old 01-23-2004, 11:08 AM
jluetjen's Avatar
Steel is a lot tougher then carbon fiber, and also cheaper to engineer and fabricate. Carbon fiber works great if you can spread the loads out over a wide area, like a monocoque. Steel can be used the same way -- check out a stock 911's tub. While Carbon Fiber is very strong, there is a significant difference in the strength depending on the grain of the fabric. This is managed in carbon fiber tubs by careful design of the weave pattern, material choice and assembly processes.
Steel on the other hand is pretty strong no matter what direction it's orientated. It is also much tougher then carbon fiber. If you overstress carbon fiber, it shatters. If you overstress steel, it bends before it breaks. It can also be fabricated by any number of competant welders, and will often even work reasonably well if fabricated by a bad welder.
Keep in mind that the stresses imposed on a bicycle frame are a significant order of magnitude less then those imposed on a competition car.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 01-23-2004, 11:10 AM
I would rather be driving
jpnovak's Avatar
Probably due to safety. steel will absorb an impact as it bends. CF will just explode and shatter. Not so much of an issue on a motorcycle where you don't have a cage of protection around you.
Old 01-23-2004, 11:11 AM
Senior Member
... yeah, I was going to say that too.
SCWDP
Old 01-23-2004, 11:13 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
I don't know CF that well at all but I would think that the steel would make for quicker repairs trackside compared to CF.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 01-23-2004, 11:23 AM
Automotive Monomaniac
Emission's Avatar
I'd say cost, then safety.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 01-23-2004, 11:35 AM
Randy Webb's Avatar
One other note -- there are some really killer steel alloys out there now -- PAG has insisted on using these high strength steels in all their cars -- even in parts of the C-GT.
I think the next step up would be to use a Ti unit body -- we just need to melt down a few more Russian submarines.
Old 01-23-2004, 11:38 AM
anh911's Avatar
Cost - if you have an F1 budget it's CF, otherwise for the most part steel is much cheaper and easier to work.
anh911
'94 Dakota - Meh
'98 Moto Guzzi - woo hoo
911; XJS; Islander 36; All Sold
'97 YZF1000RJ - Totaled (Not by me)
Old 01-23-2004, 11:39 AM
Kevin Stewart's Avatar
I just cant imagine a cost effective way to join the tubes of a cage or a webbing structure to support the chassis, Kevin
Old 01-23-2004, 12:18 PM
Cost and maintenance!!!
If you want to make a CF chassis strong enough for a 2,500 lbs race car to handle the stresses of 150+ mph and the various impacts get your wallets out. Hence the cost of a F1, CART or LeMans Chassis.
Repairs......don't even think about it with CF. Ask someone who works on F-18's!!
Tubular Steel....not too tough to find someone who can weld a crack or cut and weld in a new section when you get a bent tube.
Fritz
1987 944S
1973 911E
Old 01-23-2004, 02:14 PM
