Updated : Need opinions on my new ride height
I spent last weekend grinding swaybar brackets and installing new ones then lowering the car all around. I drove the car to work for two days this week and it has now settled. Now I am thinking it is a bit to low but want some input from you guys.
Before:
After:
Kerry
'91 C2T
'88 Targa - gone
http://www.pelicanparts.com/gallery/krichard/
Old 01-24-2004, 10:02 AM
Somewhere in the Midwest
MotoSook's Avatar
Too low..looks broken
Old 01-24-2004, 10:04 AM
Porsche Less Member
k9handler's Avatar
Send a message via Yahoo to k9handler
looks fine...no rub?
Oh, what size tires are they?
H.D. Smith
2018 Ram Power Wagon "Crystal Black"
2016 Dodge Charger SRT "Go Mango"
2019 Can Am Renegade 1000R XC
Old 01-24-2004, 10:05 AM
broken?
Kerry
'91 C2T
'88 Targa - gone
Old 01-24-2004, 10:07 AM
No rubbing, the rear tires are 225/50 16s.
Kerry
'91 C2T
'88 Targa - gone
Old 01-24-2004, 10:09 AM
dickster's Avatar
whats the fender measurements?
Rich
'86 coupe
"there you are"
Old 01-24-2004, 10:17 AM
Well I just measured for the first time since it settled and it ended up at 23.5 in the rear. It started at 24.125 when I first lowered it. The front is at 24.5 and is holding steady. I am considering coming down another .5 in the front and up .5 in the rear. I just hate having to pull everything apart again, but that's the way it goes right.
Kerry
'91 C2T
'88 Targa - gone
Old 01-24-2004, 10:27 AM
MotoSook's Avatar
Kerry, the rear looks too low. And by vroken, I mean it looks like a car with a broken rear spring or t-bar. I like a lowered look too and plan to lower my car after a suspension R&R. You wanted opinions...well, mine is that low is good, but too low looks crappy and serves no purpose..unless you want to impress the low rider crowd. just my opinion.
Old 01-24-2004, 10:40 AM
Send a message via AIM to fintstone
Too low in back...ricer or lowrider. Nice car!
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 01-24-2004, 10:42 AM
Larry Harris's Avatar
Your back appears too low, maybe take it up at least .50. My front is at 25" and my rear is about 24 1/2. I just put 245x45s in the rear and am running 225x50 in the front. Only drove the car home from the tire shop. No apparent rubbing. Drive your car 10 days or so and see what happens.
Car looks great!
Larry
2001 Turbo
Old 01-24-2004, 10:43 AM
I didn't mean to sound like I didn't want your opinion Souk, I do. When you said broken I was wondering if you saw something I wasn't aware of. I do agree it looks pretty rediculous at this ride height. I am about to order some cup2 wheels with wider rubber on them so I'm positive it will have to come up to prevent rubbing.
Kerry
'91 C2T
'88 Targa - gone
Old 01-24-2004, 10:48 AM
MotoSook's Avatar
I guess my response came off a bit harsh sounding .. no biggie right?
There are lots of pictures on the BBS...study them. The ones with just a bit of a gap between the top of the tire and the fender from a horizontal plan view look best IMO. Have fun...
Old 01-24-2004, 10:54 AM
When you reset the ride height in the first place....did you re-align the two piece rear spring plate? If you didn't....good! Porsche thoughfully put the two pieces together so that it only can be raised...not lowered. Gives you another 1/2-3/4" to play with without having to re-index the bars all over again.
If, however, you re-aligned the two pieces to allow a smidge of up and down motion later...then you've halved the upside potential. Still better than re-indexing.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-24-2004, 03:25 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Besides looking odd, another problem with being too low is that you sometimes can't set the alignment to the specs. you may want.
Too low in the front without raised spindles can mess up the suspension and steering geometry.
I also think it looks too low.
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 01-24-2004, 03:31 PM
Bill Verburg's Avatar
I agree to low in the back. But whatever height is finally used the general rule of thumb of 0.25" - 0.5" higher at the front lip will give the desired nose down rake.
Bill Verburg
Old 01-24-2004, 03:51 PM
Will, I left the ride height adjustment at factory settings so I should be able to use them to raise it back up. I just need to order the ride height adjustment wrench from our host so I can do it. Guess it will be next weekends project.
Kerry
'91 C2T
'88 Targa - gone
Old 01-24-2004, 04:16 PM
Kerry:
Right..unless a previous owner putzed around and changed the two piece relationship settings....you should be able to raise it, as noted.
---Wil
Wil Ferch
Old 01-24-2004, 05:53 PM
I placed an order with Pelican for the adjustment wrench. I will post pics later this week and get opinions on the raised height. Thanks for all the input.
Kerry
'91 C2T
'88 Targa - gone
Old 01-25-2004, 07:50 AM
Jon Merck's Avatar
Kerry,
Lowered looks better. I'm at 24 1/2 F, 24 R.
Jon
Jon
Old 01-25-2004, 08:23 AM
It may not rub at that height. I have 9" cups on the back and it looks about the same height. Their tucked in the wheel wells. It looks ricer to me too. I am not ready to deal with it right now though. I think you should try living with it for a while and see if you like it. That way I won't be all alone
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 01-25-2004, 08:52 AM
