-   -   3.6 conversion update (http://forums.pelicanparts.com/porsche-911-technical-forum/145572-3-6-conversion-update.html)
code7rpd 01-27-2004 06:32 AM
For those of you that have done the conversion, where did you guys route the DME harness? Did you emlarge the existing hole, go through the area near the upper left shock, or near the left floorboard?
Embs 01-27-2004 06:42 AM
YES, you have to use what I call a wrench panel punch to enlarge the hole. Also, that metal is wicked strong, you have to put some serious A$$ into this, it is a VERY manual job. I have a hydraulic punch set-up but there is no way to get the required stuff into the confined area.
http://forums.pelicanparts.com/uploa...1075214519.jpg
code7rpd 01-27-2004 07:46 AM
What size diameter is that one - 2" or 2.25"? Where can I get one of thoise panel punches? So, I should just go through the stock hole and mount the DME under the passenger seat?
Kevin Stewart 01-27-2004 08:38 AM
If I remember right it is supposed to go in the drivers side rear seat kick panel, you probably can enlarge the hole but you will need to put shrink rap or something to keep the eliments from getting to it, Kevin
code7rpd 01-27-2004 08:55 AM
According to Timmin's kit, he puts it in the driver's side rear kick panel and routes it under the driver's seat. I think I may opt to do that - I wonder if a hole saw will work is the the panel punch alot better?
surflvr911sc 01-27-2004 09:06 AM
Unless you modify the harness seal, the "right" way to do it is to run it through upper drivers side firewall, by the shock tower. Then run the harness around the side panel and then under the carpet to the ECU under the driver seat.
Kevin Stewart 01-27-2004 09:11 AM
I put my harness through the firewall, i dont have back seats and plan a rs carpet, Kevin
code7rpd 01-27-2004 09:14 AM
Got it. Hopefully I can get the wiring done this weekend.
Kevin Stewart 01-27-2004 09:17 AM
The wiring is a piece of cake, email me direct if you need more info, Kevin stew09@aol.com
code7rpd 01-27-2004 09:39 AM
Cool, thanks Kevin.
vash 01-27-2004 09:54 AM
my god man! this is like one of those "blow you away" articles in some magazine. you guys are too too slick. i dont realize the magnitude of knowledge some of you weekend mechanics have. where in northern cali is this project? can i come and see?
btw..in my american muscle car days. the paint job is the last step. any advantage to doing it first?
Embs 01-27-2004 09:59 AM
You do put the harness through the same hole as the other. It just needs to be made larger to get the Motronic connector through and fit/seal the larger grommet that is on the new harness .
Moses 01-27-2004 10:30 AM
Hard to paint the engine bay with the motor in it!
code7rpd 01-27-2004 10:53 AM
Exactly - I had to paint the engine bay! I am in Lafayette - PM, you can check it out - no problem.
vash 01-27-2004 11:27 AM
i guess it is way more hazardous to drop a motor into a car rather than do all the work from underneath. into the last stages of a 71 bronco build. in the beginning, we had the body shop fix rust and spray just the engine compartment. just seemed safer.
this project is amazing. i am in the east bay as well, let me know if you ever need any addtional muscle.
Embs 01-27-2004 11:39 AM
I just enlarged the stock hole to fit the new and larger grommet on the 993 harness. I forget what size punch I used. Maybe Bill Verburg will chime in here with a correct diameter. You can usually rent this type of punch set at a tool rental facility.
surflvr911sc 01-27-2004 11:50 AM
Stock hole? You have a Carrera right Todd? The earlier cars did not already have a harness hole there. 2 1/4" is about right, I have the actually size in mm at home if you want it.
Speedster94 01-27-2004 12:12 PM
cable route
hallo
Here is a Picture that may help ,if you enlarge the upper left edge
where it goes trough ,right above the Crossmember.
Harald
http://forums.pelicanparts.com/uploa...1075234225.jpg
Embs 01-27-2004 12:21 PM
I am talking about this location:
http://forums.pelicanparts.com/uploa...1075234876.jpg
surflvr911sc 01-27-2004 12:23 PM
Hard to tell where that is Todd.
