bolt holding oil pipe clip - how does that work
Hopefully an easy one this, we are about to tackle changing the oil pipes that run from the dry sump to the thermostatic valve on a 1984 3.2 supersport (turbo look in US I think).
Having lubed everything up ready, we were checking out the clip that sits on the top of the inner wing 1/2 way between the dry sump and valve, it just holds the 2 pipes in place. The stud and nut look really bad, the concern is what if we strip the stud or break it off? I am assuming it is just welded on the body is that correct?
It appears to be located to a chassis member, I dont think you can get behind it - does this sound about right?
Many thanks
H
H
'87 911 Euro
Old 01-25-2004, 10:08 AM
vash's Avatar
yes, it is a M6 stud welding in place.
poof! gone
Old 01-25-2004, 04:08 PM
Unfixed, many thanks - we have got it off now.
H
'87 911 Euro
Old 02-01-2004, 12:05 PM
