84 seats in a 70
I picked up some 84 seats to put into my 70. The rails are about 1" narrower on the 84s'. Is there an A-daptor kit available?
A fellow Pelican gave me a great deal on them so I don't have a lot invested in them yet. I'll checked our host but nothing came up. Jack Olsen what did you do? Does anyone have a pattern? I figured I can make them out of Aluminum.
Thanks, Mike When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE. 1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation) |
Some one posted a template with dimensions...look under Bielstein, I believe....
---Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
I made some out of steel that I purchased at a local hardware shop. It was pretty easy. Simply drilled the holes. There was a link either here or the 912 forum. Do a search.
I would be concerned about using aluminum. Is it strong enough to hold you in if you were in an accident?
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
here's that link..
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car |
I have actgually done this, and I find the seats are too high, this last weekend I try to figure out a way to lower them, could not see an easy way, short of a lot welding etc....
any ideas Jim
Jim Hamilton If everything seems under control, your not going fast enough. |
Not that I reccommend this but..... The PO for my car just bolted them to the floor with spacers.. ARGHHHHHHHH!
Regards, Andrew M
You should look at steel plates for this use.
You also need to consider how you will attach your seat belts. When i installed my 1977's in my '73, I had the adapter plates made up with a set of threaded "ears" to anchor the lap points. ANDREW15 - Thanks for the link. I was looking for that a while back and could not find it.
