rickeolis's Avatar
Porsche Crest SSI's for 2.7'S' question-
From what I have read, if I simply buy a set of SSI's designed for a 1969 911T engine, they will simply bolt onto my newer 1975 2.7'S' engine?
I have no emission requirements and want a set of SSI's. What should I order?
-Rickeolis-
1986 Corvette
Old 01-26-2004, 01:43 PM
vash's Avatar
you need to look into the oil line differences. i think wayne covers the details in his web site.
poof! gone
Old 01-26-2004, 01:51 PM
rickeolis's Avatar
Porsche Crest
Yeah, the P. Parts website claims 1978- on, for oil line differences, thanks-
Copied from Pelican:
"Oil Line Update: It is important to note that all cars with cross-over exhaust systems (all 1978-89 911SC and Carrera) require the replacement of two oil lines with two older-style ones when installing the SSI heat exchangers (or any 1974 and earlier exhaust). These lines are part numbers C-107-728-00 (cars with a front-mounted cooler) and C-107-729-10 (no front-mounted cooler) and C-107-739-10 and are available for purchase below."
-Rickeolis-
1986 Corvette
Old 01-26-2004, 02:10 PM
vash's Avatar
oh good! i was going to look, but i saw my boss coming so i had to minimize and punch up a graph or something. haha
poof! gone
Old 01-26-2004, 02:18 PM
Rouxzy's Avatar
Rickeolis,
I put SSI's on my '77 which would be the same engine as your car and I think I remember that you can only use back as far as '74. The '73 and earlier take a different set. What I would do is contact SSI yourself and ask. They are a pretty good bunch of guys if you are asking about their products.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 01-26-2004, 02:20 PM
rickeolis's Avatar
Porsche Crest
Glad I asked! I'll contact them and have them let me know about it, thanks!
-Rickeolis-
1986 Corvette
Old 01-26-2004, 10:03 PM
rickeolis's Avatar
Porsche Crest
Got it, thanks Wayne.
The first two models cover almost all the years without the needs for emissions, now I see it.
I'm building my order list-
-Rickeolis-
1986 Corvette
Old 01-27-2004, 02:21 PM
Cool
you may want to confirm the exhaust stud length that'll match the thin or thick SSI flange.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-27-2004, 04:07 PM
rickeolis's Avatar
Porsche Crest
Thanks Ronin, that's exactly why I ran this post. I'm hoping for input from those that have done this to a 2.7-
Anyone??
-Rickeolis-
1986 Corvette
Old 01-27-2004, 06:34 PM
Hey rickeolis,
Here's what you'll need:
ssi's with the thin flange - you have shorter studs than the later engines
oil line kit to re-locate oil line (if you have external cooler)
two - in muffler
gaskets
new copper hex nuts
new allen nuts
oil line wrench or large adjustable
a 13mm(I think) socket w/ universal joint adapter
one 13mm offset wrench
one allen wrench - long to fit through access tunnels in exchangers
WD-40 or similar to soak studs
gunk or latex gloves
patience
band-aids
that's all I can think of. The conversion is well worth it. Have fun.
Chris
'75 911s 3.2 - Ice Green Metallic
87 951, '05 987 S
'14 Audi A6 3.0
18 Tesla ModelX 100D, 20 Model 3
Old 01-27-2004, 07:34 PM
Cool
yep,
my 2.7 had the long studs so I needed the thick flange SC SSI..
no problem.. I ordered a plug and gasket for the O2 bung from SSI.
Eventually I'll use the bung to hook up a smog maching for a$$ hole SUVs that tailgate, on purpose to break my balls.. when I'm in the right lane in dangerous territory. So don't be discouraged if you need thick flanges.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-27-2004, 07:45 PM
rickeolis's Avatar
Porsche Crest
So, I see that some 2.7's have thick flanges, and some thin?
-Rickeolis-
1986 Corvette
Old 01-28-2004, 09:53 AM
Send a message via AIM to fintstone
I have '74 SSIs on my car. You can come by and look if you like. They were on my 2.7, but switched them to my new 3.0.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 01-28-2004, 09:25 PM
Most likely thin on your '75 engine. From my experience, the thicker flange SSI's also have extensions that "plug" into your exhaust ports. I believe the 2.7 has smaller exhaust ports than the 3.0 and the thick flange SSI's won't fit even if you replace the studs. If you buy the thin flange SSI's and realize your studs are too long, you could replace the studs. This is what I had to do on my 3.2 to get the SSI's from my 2.7 to fit.
Chris
87 951, '05 987 S
'14 Audi A6 3.0
Old 01-29-2004, 06:12 AM
Otto's Avatar
Here are the parts you need:
911 211 021 60 Heat Exchanger Left Side Stainless Steel Carbureted and CIS
911 211 022 10 Heat Exchanger Right Side Stainless Steel
900 075 148 02 Bolts 10 x 32 (4)
999 084 002 02 Hex Nuts (4)
901 111 193 00 Gaskets (2)
900 028 008 02 Washers (2)
900 076 010 02 Hex Nuts (2)
901 111 195 00 Gasket (6)
900 076 025 02 Hex Nut (6)
999 085 001 02 Barrel Nuts (6)
901 211 193 00 Hearter Hose
901 211 194 02 Heater Hose
999 512 128 02 Clamp (4)
911 111 025 01 Muffler
901 111 151 04 Bracket
901 111 157 04 Clamp (2)
900 067 078 02 Bolt (2)
900 025 00702 Washer (2)
900 028 024 02 Washer (2)
900 076 025 hex nut (20)
911 107 739 10 Oil Line Engine (Pump) to Tank or Regulator
911 107 743 10 Front Oil Cooler Engine Pipe to Regulator
Otto
Racing Porsche for over 30 years.
http://www.OttosVenice.com
Check out the Porsche Owners Club Track event Videos
Old 01-29-2004, 07:26 AM
rickeolis's Avatar
Porsche Crest
Thanks guys, I am going to go ahead and order the thin flange style today from Wayne and the boys.
Fintstone, I would love to see your car soon, I'll send you an e-mail.
Otto, nice web site! I hope I don't need everything on that list though, but we'll see, thanks.
I have an original early 2-in-1-out muffler, but I want to try one of those Stinger style setups to help save weight and increase flow.
-Rickeolis-
1986 Corvette
Old 01-29-2004, 08:46 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
