Paul Franssen's Avatar
What "hollow" parts are there to a 911 unibody?
I'm in the winter process of doing some rust preventive work to my Carrera, nothing fancy like a rebuild or similar, just spraying Tectyl "ML" and "Bodysafe" on the bodyparts I can reach... I understand these products to offer decent quality protection against rust and that's within the scope of what is intended and that I can handle...
The "ML" product is meant to be sprayed in "hollow" areas. Which I've done: where ever I find a hole, I spray into it...
My question is: what exactly are the hollow parts of a 911 "chassis"? OK, there's the doors, the inner rockers...
Subsidiary question: I've found some small holes on the bottom, some of them are plugged with a rubber plug, others are not.
(What are these holes for? The plugs look original Porsche...)
I've read that these small holes may let puddle-water in, to soak the carpet above, and generally dampen more than just the spirit... A Frenchman reportedly plugged those with custom cut-to-shape old wine cork pieces.. I thought it might be easier to plug them with chewing gum. Any counterindications against the use of chewing gum (this is a serious question, not intended to be a joke!)?? Silicone is another possibility, but that's such a mess to work with!
Belgik
1988 Carrera 3.2L
Old 01-27-2004, 02:23 AM
I wouldn't use silicone stuff to keep water out.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-27-2004, 04:41 AM
I would rather be driving
jpnovak's Avatar
you can get to the rear longitudinals/dog legs in the engine bay through the rubber plugs after removing the tail light housings. They are right there in the square box section.
Did you do the:
front lateral tank supports
Front center tank support
front strut towers
inner rocker
outer rocker
latch post
A, C pillars (requires headliner removal)
box section between nose and front pan
area between rear windshield lower lip and rear deck
Sometimes you have to drill a small hole to fish your spray tube through. Best way to spray is to get a tube that fits in the spray head (think WE40 can) fish this tube as far as possible. estimate the depth by laying outside panel. Start spray and slowly withdraw tube leaving a coating over the entire surface. Best of luck.
72 911T project car. "Minne" - A tangy version of tangerine
classicautowerks.com - EFI conversion parts and suspension setups.
Old 01-27-2004, 06:00 AM
911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest
Paul,
Are these the plugs you're talking about?
I'm trying to get a "tectyl" spraying diagram. If I can find it, I will email it to you.
You can find a general guide-line at: www.tectyl.com
> tectyl > tech bulletins > tech bulletin # 17
Kees.
Old 01-28-2004, 04:42 AM
From the 911 restoration book by Morgan and Porter I copied the following pics.
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 01-28-2004, 09:33 AM
part 2
And Kees, if you might find a tectyl diagram I would also appreciate a copy
Peter
'13 981S
'73 911T
Old 01-28-2004, 09:36 AM
djmcmath's Avatar
I'm going to come right out and ask the stupid question -- just a couple days ago, there was a big thread on how the chassis gets electrostatically plated and is essentially impervious to rust. There's no way we can duplicate that process without a massive factory because it gets inside all the nooks and crannies that you can't reach. Peter, I'd believe that your '70 would be old enough to not be treated, but wouldn't Paul's '88 be taken care of? Were there parts that didn't get dipped in the magic electro-coating, like bumpers, doors, hoods that would benefit from this? It looks like the guy in your pictures is doing chassis-type stuff, though. (confused shaking head) I don't understand...
I apologize if I've totally missed the boat on this one, but it seems like a pretty massive duplication of effort, in my admittedly knowledge-limited opinion.
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 01-28-2004, 11:19 AM
Dan,
my 2ct
At least for my year part of the underbody was galvanized. In later yeas the whole car was galvanized. This basically only slows corrosion down.
I thought all models went through a electrostatical coating bath.
The problem with all those box sections is that they are not very well ventilated and therefore stay damp. The wax that is sprayed into the box sections seals all seams and prevents the moisture from doing harm. I believe most new cars receive some kind of wax treatment in the factory
Peter
'13 981S
'73 911T
Old 01-28-2004, 11:36 AM
djmcmath's Avatar
Peter -- that helps, thanks. I think I understand the problem. Now I'm thinking I probably ought to go out and fill my hollow spaces with stuff, too ... BTW, by "most new cars," do you mean "new" as in '78, or "new" as in '98?
Dan
Old 01-28-2004, 12:18 PM
New as in today.
Peter
'13 981S
'73 911T
Old 01-28-2004, 01:23 PM
djmcmath's Avatar
Ok, cool. Thanks.
Dan
Old 01-29-2004, 09:35 AM
Grady Clay's Avatar
Peter,
My recollection is that the ’77 model year was the first for galvanized bodies. I know that some were, I don’t know if all were.
To maintain a 911 in places like the Low Countries (The Hague & Seattle) and most everywhere else is to get your 911 dry and keep it that way. Heat/AC sealed garage, dehumidifier, consistent temperature, and some air flow through and around the car.
Here in Colorado we have 24”Hg (0.8 bar) atmospheric pressure and typically 10-40% RH. The big issue is temperature variation. If you keep your 911 in a place where the environmental conditions are very stable, that is the ideal.
Tectyl is a wonderful preservative. In applying it as Peter is, I would dilute it to very thin with Stoddard solvent and make sure any excess was drained out. This allows the wax (Tectyl) to penetrate all the seams and cracks and apply only an extremely thin coating so a subsequent application or cleaning will work.
Peter, it looks like you have a really cool RHD 911S in full disassembly. Good for you.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 01-29-2004, 10:13 AM
Grady,
From the 1970 Model the entire underbody and parts inner sheet metal was galvanized. (exception the vin 9110120011 to 9110124126 and 9110220011 to 9110220667 and 9111120011 onwards).
Mine is 9111310129 so it should be partly galvanized. The pictures in this thread were taken from a Haynes restoration guide ("guide to purchase and DIY Restoration by Lindsay Porter and Peter Morgan.
My targa is in the garage waiting for the weather to improve.
Peter
'13 981S
'73 911T
Old 01-29-2004, 10:50 AM
Grady Clay's Avatar
Peter,
Good for you, your Targa looks great.
We may spend the summer ’05 race season in England and possibly on the Continent. Let’s stay connected. When you find yourself in the States, look us up.
Best,
Grady
gradyclay@hotmail.com
Old 01-29-2004, 11:36 AM
Where? I can't find it. Could you please post a link? thanks
Old 01-29-2004, 12:12 PM
djmcmath's Avatar
Prep work b/4 repaint.
--Look down towards the bottom of this one. WCroty brings it up, Randy Webb plays straight man, then WCroty follows with a pretty good description of it.
Dan
Old 01-29-2004, 02:23 PM
Kees (from Harmelen NL) yes the plugs on my car look like the ones in the picture... and if you can find the Tectyl spraying diagrams, that would be great.
I will admit, though, that I do not intend to go to the length of ripping out headliners, carpets, gas tank etcetera... to go inside the hollow parts (as seen in the above photographs): my car is 9 out of 10 in the "appearance" department, and this would be going too far. And yes, the 1988 Carrera has been extensively galvanized (but I am very very sceptical as to the degree of protection that provides "today", after some 16-17 years - I've seen my own and other Carrera's very very rusted indeed in spite of that mythical zinc galvanisation I always hear of). I have carefully sprayed (first ML, then "Bodyguard") the wheelwells (especially around the headlamp and door jamb mud-collection points), inner rockers and doors. I -basically and theoretically- only drive in good weather (but do get caught out...), NEVER on salted roads (if possible), always extensively wash the car (only after she's been wet...) and keep a good wax on her. She's parked in a dry garage (heated by the house heating burner nearby...), with chemical de-humidifying boxes under her and one inside. Other than demonstrating that I am applying "due diligence", I hope it will impede the rust devil...
Belgik
1988 Carrera 3.2L
Old 01-30-2004, 12:12 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
