High torque 215mm clutch needed
Now that my 2.8 engine is done, it has overwhelmed the clutch in my '69 911 (215mm 911S clutch) I estimate I'm getting around 210 ft-lbs of torque from the engine, and I can break the clutch loose in any gear at WOT. My question is, is there a high torque clutch available for the 901 trans, and the 215mm flywheel? (Besides the 69 911S one) I don't want to go to the pull-style clutch if I don't have to.
Thanks, JP |
Yeah, Kennedy makes a 228mm flywheel and clutch assembly....kevlar clutch.
http://www.kennedyeng.com/ |
| All times are GMT -8. The time now is 10:19 AM. |
