drag racing the short bus
dd74's Avatar
Angry Nail in tire, now what?
The roofers at our building seem to be quite sloppy in their work, as they seem to have discarded very large nails throughout the parking lot.
I worked late tonight, and of course, ran over one despite my careful check of our dimly-lit parking lot. Currently, a large nail (with washer ) is embedded in my left front tire, and I feel it with every rotation of the wheel.
These tires are quite new - they are Yokohama EVS-100s, 205-50-15s, with quite a bit of tread on them. In any other circumstance I would plug the obvious hole that will be left when the nail is pulled out. However, I take these tires to the track and on our Mulholland runs. In short, I rely on them quite heavily, and drive on them very spiritedly.
With that in mind, can someone on the board advise me if, given the pressures I put these tires under, it is safe to plug and use the tire for track work and canyon carving, or should I simply mount on a new tire. The building's owners have already agreed to pay for this. Also, if I do get a new tire, how will having a "newer" tire effect the other three tires and most importantly, the balance of the car.
P.S.: one way or the other, I'm saving the nail as I plan to put it through the roofer's palm in a partial crucifixion!
Thanks in advance.
The Terror of Tiny Town
Old 01-28-2004, 09:22 PM
I would definitely mount a new tire, and let the handling "come in" with mileage. Plugs are good for low speed truck tires, but don't trust them with your life.
Besides the fact that it would always be on your mind, and if your anything like me, there isn't room on mine!
Mike B.
'72 911E Coupe
Early "S" #1065
Old 01-28-2004, 09:28 PM
dd74's Avatar
Yeah, you're right. I've plugged truck tires before, and even they sucked after it was done. Plus, the "clicking" from the plug was just as loud as what was pulled out.
Old 01-28-2004, 09:34 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
BS! Take that sucker to a "tire" guy and have it fixed! There is no reason that a roof nail cannot be repaired and be completely safe at the 160+ mph you will be hitting at WSIR!
Really, get it fixed.
Old 01-28-2004, 09:39 PM
Sonic dB's Avatar
Hopefully you got them from Americas tire co. and paid for the road hazard warranty.
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Definitely new tire time. We're talking about a $75 tire, dude. Buy two and the difference up front will disappear. Get some cement, make a volleyball net from the old fronts, park the Porsche nearby, and wait for the bikinis to show!
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 01-28-2004, 09:40 PM
You guys are serious??? For my truck, I plug them myself, never had a problem. For the P-car I would take it to the shop and have it patched from the inside then rebalanced. Really, a $20 patch will last longer than the tire. Trust me, Iím not cheap when the odds are close but this isnít one of those times.
Paul (pbs911) had a patch done before his last run at WSIR, donít worry about it Dave, get it fixed and put the money elsewhere.
Old 01-28-2004, 09:49 PM
Buy them, sell them
Adam's Avatar
I'd just plug it, but if the building is willing to buy you a new AVS, I'd let them.
Seriously, if it's plugged properly, you shouldn't be able to hear the plug. My old Pirellis (which aren't even on the car anymore) have two plugs in them and they've travelled less than 3k miles.
But the plug-job was first class.
1968 Ford Mustang Fastback
1985 BMW E28 M5 Clone
1989 911 Carrera 3.2 Cab
Old 01-28-2004, 09:50 PM
dd74's Avatar
I don't know, Ryan. At speed do you really trust a tire patch?
I was even thinking of somehow having all the tires shaved down to the same height so I won't have to go through that much of a "break in period."
Old 01-28-2004, 09:52 PM
I have used plugs in my tires, and run them 'til they were nearly bald with no problems.
The things that a good tire shop will use these days are a patch/plug. It's kind of like a giant rubber roofing nail. It's got a thick shaft that goes through the hole in the tire from the inside, and then a really big flat head that is also glued/bonded to the inside of the tire. I'd say that these things are pretty darn sturdy, especially since the pressure is going to be pressing on them from the inside out.
But hey, if it makes you feel better then get a new tire, it's not that big a price to pay for peace of mind especially when your life is riding on it. Even better if you can get someone else to pay!!
Old 01-28-2004, 09:59 PM
I would trust the tire much farther than I could push the car.
I've had tires w/ 5 plugs in them, never leaked. I'm not saying to plug it though, I'm saying to take it to a independent tire guy and have it properly repaired, which usually means a patch on the inside.
If they say Ēno wayĒ (I have $20 bucks they donít) then fine, get a new tire, as long as they arenít the ones selling it.
Trust me, tires are tough, properly patched tires are good as new. If your fuel tank needed a repair I would probably say get a new one, Iím sure someone has had one successfully patched though.
Old 01-28-2004, 10:05 PM
dd74's Avatar
It's just that stinking break in period that I'm not up for. Hmmm...
So you "patchers" out there truly trust them on a track?
Old 01-28-2004, 10:07 PM
We are talking about a 1/8 th nail, in a steel reinforced modern high speed tire. Not that I think you should try this but if you arenít loosing pressure now, I bet you could cut the head off, to get rid of the noise, and go out to Willow and run w/o any pressure drop at all.
Dave, take the tire to them, have them dismantle it, be honest about how you are going to use it, and let them be the judge. My money is on you getting many more miles out of that tire.
Old 01-28-2004, 10:17 PM
SteveF_911's Avatar
I ran on the track with a plug for about 6 events. Ran the car up to about 12o mph.
As long as it is not in the sidewall it will be fine.
No problems the tire lasted right to the canvas.
66 911 with S engine
2008 Westfield XTR2
1999 Toyota tow vehicle
& a 2009 fordy thingy
"Contraception should be used at every conceivable opportunity"
Old 01-28-2004, 10:57 PM
dd74's Avatar
Steve, Adam, Ryan and others - thanks for the advice on this. I'll see about a patch tomorrow and tell you what comes of it.
Thanks again.
Old 01-28-2004, 11:28 PM
scottb's Avatar
Dave: Get the name of the roofers, and bring a small claims action. I'll bet you the $20 patch charge that their insurance carrier gives you a new tire before the matter comes up for hearing.
1984 Targa
Old 01-28-2004, 11:32 PM
Next time you attend a track event, ask the organizers how they feel about patched tires. Many of them won't allow you on the track if they know about it.
Old 01-29-2004, 12:13 AM
hpmad's Avatar
Hello,
I have a patch in my front left tire, from a nail too, and I have no problems whatsoever, never even thought about the fact that it could be a problem (and I did not even pay for the patching as I went for a weel allignement, and as I was doing so, I asked the guy to see why that tire was loosing pressure, and he fixed it and showed me the HUGE nail that he got out of the tire :-)
cyrille
Old 01-29-2004, 05:04 AM
MonkeyBoy's Avatar
Also have the roofers send one of their flunkies back to the lot with a magnetic roller to make sure this doesn't happen again. Your time is worth WAY to much too deal with other people's incompetence.
Old 01-29-2004, 05:18 AM
Send a message via AIM to fintstone
I would not plug the P-car, but I have mine patched without problem...
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 01-29-2004, 05:44 AM
