Cylinder studs - Dilivar or gray steel?
What's a good reliable choice for cylinder studs for rebuilding a 3.2? (I don't want the expense of Raceware and I don't plan on tubocharging)
Divilar or standard gray steel?
Old 01-29-2004, 06:17 PM
Steel
Edit - I guess I should elaborate - dilivar has better thermal expansion properties, but is prone to corrosion. This may or may not be a concern, depending on how long you keep the car.
When I was rebuilding my 930 engine, I replaced the dilivar with OEM steel. No problems.
Your Carrera, I believe, has 12 steel and 12 dilivar. Someone correct me if I'm wrong. It would be OK to replace just the 12 dilivar.
Old 01-29-2004, 06:20 PM
Good question. I'm about to replace all of mine.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 01-29-2004, 08:30 PM
Friend of Warren
Wayne and John Walker both recommended I go with steel uppers and lowers on my 3.2 so that is what I did.
Kurt V
Old 01-30-2004, 06:12 AM
Super Moderator
cstreit's Avatar
993 Studs... Steel ones. Cheap and reliable.
Chris
2001 GT3 Cup - "Pepin"
1999 Spec Miata
1996 993 RS Replica
2010 Harley 48
2013 Honda 250 CRF
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-30-2004, 06:58 AM
I followed John Walkers advice on my 3.0 too. Steels on the bottom. Same part number as the ones used on the intake side.
John Adams
1980 ROW 911SC
Old 01-30-2004, 08:54 AM
OK, standard steel looks like the ticket. Wait a minute, I remember VW's needed something called case-saver inserts to handle the additional pulling forces on the studs. Since the steel studs will not lengthen like the OEM Dilivars when hot would case savers be a good idea and are they available?
Thanks!
Old 01-30-2004, 09:16 AM
3.2's DO come with 12 steel and 12 Dilivar..
Save some $ and replace only the 12 Dilivar with steel...factory / ARP / or Raceware....
--Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-30-2004, 09:54 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Chris, Are those the all threaded ones??
Ingo
'74 Targa 3.6 (not stock ) - '01 C4 (almost stock) - '00 ML430 (stock)
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2 - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 01-30-2004, 09:59 AM
No offense intended, but a set of Raceware studs is relatively inexpensive insurance when compared to the hassle of having to remove a broken one.
When building racing or street engines (including V-8's in the past), I have always used either ARP of Raceware and have never had a broken fastener.
Lindy
Old 01-30-2004, 11:12 AM
Friend of Warren
I've never heard of a broken steel stud on a street driven 3.2!
Kurt V
Old 01-30-2004, 11:14 AM
Thanks!
Old 02-01-2004, 02:57 PM
Casesavers/Timeserts are commonly used on the magnesium cases, but not so much on the aluminum cases (like yours).
I just cleaned up the threads with a tap and then installed the steel studs on my 930 engine (with red Loctite).
Old 02-01-2004, 03:05 PM
what is the best to go with on a 2.7 with a turbo on it? i have the black coated dilivars but the coating is comming off? im a wd for arp but i was told not to use those on mag cases?
Old 02-01-2004, 08:46 PM
Birel:
Probably steel in combination with Time-Certs...
Turbo 2.7 ? ... yeow !!
---Wil Ferch
Wil Ferch
Old 02-02-2004, 06:09 AM
Senior Member
Jdub's Avatar
About cleaning the threads: Are you folks using a bottom tap? If so, how are you removing any swarf at the bottom of the threaded section?
John
'78 Targa | WANTED TO BUY - NORTON COMMANDO PARTS - PLS MESSAGE.
Old 02-02-2004, 07:12 AM
