930 engine misfire
I have a 1989 930 that I've had for 2 years. It has been perfect up to a few weeks ago. Since then, on 3 occasions, it will run rough with "wild swings" of the tach. At a constant speed (mph), the tach will indicate 2X the expected rpm, and the engine runs as if on 3 cylinders. I drive home, shut it off, re-start, it runs perfectly again! Then runs perfectly the next half dozen times, then repeats the above.
Problems the DME? Electronic ignition? Coil?
All ideas appreciated!
Thanks. Bob
Old 01-31-2004, 04:53 PM
Unless it's wildly modified, your 930 has CIS, so no DME.
It sure sounds like it could be an electrical issue between the CDI/distributor/coil. I'd start looking at the connections in that area. Have you checked the ground cables in the engine bay? Cleaned all the electrical connectors and used dielectric grease on them? You can start with the distributor's 6-pin CDI connector, and the main 14-pin connector.
The CD box could also be failing.
Good luck
Old 01-31-2004, 06:34 PM
rotorhead's Avatar
Almost certainly it is the voltage regulator on the alternator. An easy way to check is measure the battery voltage while the engine is running it should read around 13.5-14.5v. If it is much higher then the voltage regulator has failed.
Dont drive your car with high voltage, the engine management system and speedometer can fail.
It is a very simple (2hour) job to replace it
2008 BMW 320i
2006 Mercedes ML320
2004 Mercedes ML270 cdi
1998 Porsche Boxter
1988 Porsche 930 Targa (sold)
Old 02-01-2004, 06:53 AM
beepbeep's Avatar
Engine managment? :-) There should be some Lambda circuitry there though...
Thank you for your time,
Old 02-01-2004, 07:18 AM
Forced Induction Junkie
WERK I's Avatar
I agree with Steve Hall. I had the same problem with my turbo. Mine happened when I turned on the headlights. Engine would misfire and not pull very strong. I removed the alternator and pulled the regulator/brushes assembly. Brushes were worn down almost completely. I inspected the commutator shaft that the brushes ride on and it was worn down considerably. I had to replace the alternator because of the commutator problem.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-01-2004, 09:25 AM
Hmmm, interesting. I've never heard of an intermittant VR failure, but maybe it's a heat-related thing? It's cheap and easy to check the voltage, I guess.
Old 02-01-2004, 09:28 AM
rotorhead's Avatar
The reason I said engine management is that if your car has DME then (I have read on this forum) that high voltage can fry the DME. But as rightly said before you 930 has CIS.
Does anyone know where I could learn more about CIS?
2008 BMW 320i
2006 Mercedes ML320
1998 Porsche Boxter
Old 02-01-2004, 04:19 PM
