DJB DJB is offline
DJB's Avatar
High and Low Beams on together?
Just finished installing the Sucro relay kit in my 86. What I have noticed and this was probably happening before the install, is that both high and low beam operate together when high beam is selected.
Looking at the wiring diagrams for the stalk switch (which is only 6 months old) this would not be normal operation (for any car probably).
So before I get stuck into the stalk switch and start bending contacts - any other thoughts or suggestions would be appreciated.
Cayenne Turbo - Cargraphic Stage 2 Power kit, lowering module
997 C4 Cabriolet - Basalt Black
86 Turbo Body 911 Cab - Many Mods
Gone and Missed:
97 993TT: PSS9, CarGraphic Exhaust
Old 01-31-2004, 07:12 PM
Hmm, on cars with 4 headligts the lowbeams often stay on when the high beams are selected.
Old 01-31-2004, 07:51 PM
I toasted the bulb inner ground when doing a 130/100w both hi&low on at the same time.. not a bright idea. it lasted about 1hr on high.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-31-2004, 08:07 PM
DJB DJB is offline
DJB's Avatar
Just pulled the stalk apart and the contacts seem to be correctly positioned and operating efficiently. I gather the next step is the headlight switch but I am struggling to understand how that could be cause.
Low beam operates correctly but when high beam is activated (switched on or in flash mode) low beam does not go off.
Any further ideas guys?
Gone and Missed:
Old 01-31-2004, 08:41 PM
you may toast ground if both on at same time.. I'm not sure with stock watt bulbs
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-31-2004, 09:11 PM
