twin plugged targa's Avatar
Crane Cams - anyone used them?
Has anyone used crane cams in their cars?
My 2.7 has a crane cam I am told.
I have visited the web site and they only show 3 possible cams for 2 litre 3 litre and 3.2 litre.
I am guessing mine is this one as the performance takes off after 4K revs. Any other way of knowing from the outside?
here are the specs:
Part Number: 520-0012 Grind Number: P-306
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1965 Up PORSCHE 6 Fair idle, moderate performance usage, good mid-range horsepower. Basic RPM 4000-6800
Engine Size Configuration
1991 C.C.
Valve Setting: Intake 0.1 MM Exhaust 0.1 MM COLD
Lift: Intake @Cam 8.49 MM @Valve 12.55MM All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 7.96 MM @Valve 11.73MM
Rocker Arm Ratio I-1.477/E-1.475
Cam Timing: VALVE @.305 MM
Lift: Opens Closes ADV Duration
Intake 51 BTDC 75 ABDC 306
Exhaust 66 BBDC 42 ATDC 288
Spring Requirements: Triple Dual Outer Inner
Part Number --
Loads Closed -- LBS @ -- or --
Open -- LBS @ --
Recommended RPM range with matching components
Minimum RPM 4000
Maximum RPM 6800
Valve Float --
Cam Timing: VALVE @1.0 MM
Lift: Opens Closes Max Lift Duration
Intake 34 BTDC 58 ABDC 102 272
Exhaust 49 BBDC 25 ATDC 102 254
Whatever all that means
rgds ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001
1971 911T Targa - twin plugged 2.7 230HP SOLD! 2/2008
1970 911T - ivory white -SOLD 2/2012
Current car:
1987 930 RUF BTR clone
Old 01-31-2004, 07:35 PM
Hmmm.. guess noone uses Crane Cams
Ok, anyone know if there is anyway that I can tell from the outside , which cams I have?.
please excuse if this is a daft question.
Also I can tell a huge change in engine tone at 4K+ revs, which I was sure was detonation.
A friend told me that a rough Porsche engine that sounded like a can of dried peas in a can at idle was that way due to race cams.
Do race cams make the engine sound rattly at idle or is it possible that the cams I have are making rattle noises at higher revs?
Again sorry if this question is daft, I am just fishing for hopeful easy answers which are not going to cost $$$$$$ in rebuilds
Rgds Ben
Current car:
Old 02-01-2004, 08:06 AM
Plavan's Avatar
I have the exact same P-306 cams in my racecar. Good balance of power and torque. I do not rev my race car over 7300k (well sometimes ) so this was the perfect choice for my race motor.
The only way to check it is to yank the cams out.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 02-01-2004, 08:57 AM
Hilbilly Deluxe
emcon5's Avatar
You can degree them, but not with the engine in the car.
Details here:
Webcam, real or fake
Ben, you really need to do some detective work, and find out who built the engine, and what he put in it.
Looking at jluetjen's chart, that is a pretty hot cam, higher lift/duration than a 906.
Tom
82 911SC Coupe
GTI Cup #43
Old 02-01-2004, 10:26 AM
dtw dtw is offline
GAFB
I have Crane P-288s in my 2.4 sleeper motor. One of 'em, can't remember which, has a stamping in the end of the cam for ID purposes. Pull your chain covers and see if yours do, too.
After spending a lot of time with modified Porsche engines, I can't say I've ever heard a healthy one sound the way you describe. Before worrying about $$$ for rebuilds, I'd go over the basics and gather some facts. Check valve adjustment, look for exhaust leaks, broken head studs, etc.
'72 911T Silver
'01 996tt Lapis Blue
Lots of BMWs
Old 02-01-2004, 11:42 AM
