21mm Master Cylinder - is there interest?
Seems to be a lot of talk about 23mm master cylinders for big brake upgrades vs. 19mm master cylinders. Some feel the 19mm is not enough and that the 23mm is overkill (or the pedal feel isn't right).
I believe that there used to be a 21mm master cylinder for the older 911s cars, but that they are NLA. If I could obtain some, would there be interest (assuming the price is right)? Post your interest here. Thanks!
Qarl |
I learned today at Dunkel's that supposedly Sportomatics came with a 20mm. Didn't ATE make a 21mm for a Mercedes model? Same bolt pattern if they did.
No, there are several reference manuals for the Mercedes master cylinder which incorrectly list it as 21mm. When you get the part, it is 23mm.
(This is what I've learned from searching the old thread posts on this board).
Qarl |
