Got Boost?
IMONBOOST's Avatar
Experts Please, Torsion Bar Tube Question
I have to order the torsion bar tube (number 16 on picture below):
What is the difference between the tube on the Carrera RS 1973 and the rest of the 911s till 1986? The RS tube is so much cheaper, it just doesn't make sense to me. Also, what about 911s from 1987 to 1989? Didn't these use torsion bars as well? I am a bit confused.
#16 Rear torsion bar tube 1969-1986
911.331.010.02GRV $927.00
#16 Rear torsion bar tube 911 Carrera RS 1973
911.331.039.00 $132.00
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work."
-Ayrton Senna-
Old 01-22-2003, 05:08 AM
dickster's Avatar
i believe the 87's on are different due to the g50 box.
don't know about the rs, too good to be true?
Rich
'86 coupe
"there you are"
Old 01-22-2003, 06:43 AM
nick-moss's Avatar
That price cannot be right, if it is, buy all the stock.
This a quote from Transend' web site
LOOK NEW TORQUE TUBES for torsion bars-for 73 RS but can be fitted to all cars from 65 upwards-genuine part -either fit with reinforcements or remove to have as original-UNREPEATABLE ONLY -£480
that is around $720!
Nick Moss - RGruppe #318
early911.co.uk
Old 01-22-2003, 06:50 AM
Got Boost?
IMONBOOST's Avatar
If I understand this correctly, the RS tube is the same piece but reinforced?
-Ayrton Senna-
Old 01-22-2003, 08:58 AM
jluetjen's Avatar
Wouldn't the RS tube also have the suspension mounts positioned for "Turbo" trailing arms rather then the non-Turbo bananas? Or would that only be on the RSR's? If you have to update to Turbo 'arms it will eat up a lot of that "savings".
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 01-23-2003, 05:51 AM
nick-moss's Avatar
Here is a picture of the torsion tube of my 74 Carrera. The arrow shows the reinforcement that we are discussing. It braces the torsion tube to the floorpan. Those are standard trailing arm mounts not Turbo.
According to Starkey the last 181 1973 RS's had the modified suspension mountings
early911.co.uk
Old 01-24-2003, 10:37 AM
nick-moss's Avatar
My PET shows 911.331.039.00 for 1973 2.7 RS from chassis number 9113601409 on, that would make it the tube with the modified suspension pickup.
early911.co.uk
Old 01-24-2003, 11:02 AM
Who did you guys find that could supply the entire torsion bar tube complete? How did you have it fitted? Does it require a special jig?
Terry
Terry
Old 02-01-2004, 06:04 PM
