-   -   wind noise on 73.5 911T (http://forums.pelicanparts.com/porsche-911-technical-forum/146730-wind-noise-73-5-911t.html)
Q-Dog 02-01-2004 08:14 PM
Hi-
New to the forum. I recently 'inherited' my late father's 73.5 911T, with vent windows. I'm trying to rid the wind noise that seems to be coming through the vent windows. I would appreciate some expertise from this knowledgble group.
I have replaced the vent window rubber and the window felt. Still lots of noise at speeds above say 35-40 mph, terrible at 65+ mph.
Any help would be appreciated.
Q-Dog
Evans, Marv 02-01-2004 09:38 PM
Q-Dog:
Welcome to another SD area member. Which windows are you calling vent windows? The front triangular windows on the doors (I didn't think they could be opened in '73), or are you calling the rear windows vent windows? Are you sure it's coming from the window and not the door gasket at the front of the door? The door gaskets need to be changed after some time because they tend to let in a lot of wind noise when they get worn.
Q-Dog 02-01-2004 09:51 PM
Evans:
Perhaps I used the wrong term. I refer to the front triangular (wing) windows. It's correct that 73.5 didn't have them but my father had them put on years ago because He preferred them.
I'm pretty sure the majority of the noise is from the wings. The door seal will get replaced next month when the car get painted.
Randy Webb 02-01-2004 09:55 PM
I also added the opening vents to my 73.5 T. You may need new rubber there.
You can use a stethoscope to find exactly where the noise is coming from.
Seal the holes in the door frame with the rubber plugs that PAG makes as an update for this.
And, realize that even when brand new, magazines complained about wind noise from these cars.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
