Send a message via ICQ to old_skul
Targa top torn - how best to seal?
Other than re-covering my top, how can I best seal a small tear (<1") in my vinyl?
I think I tore it with an ice scraper. I just need to seal it against the elements until we get some nicer weather and I can re-cover it.
Black silicone?
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 02-02-2004, 06:45 AM
targa911man's Avatar
I've seen vinyl roof repair kits in auto stores, but you might match the grain better with some imitation leather material from a fabric store. Or so my wife tells me. I'm not secure enough in my masculinity to go in a fabric store.
If you're replacing your skin, have you considered converting to a hardtop? I've got JMPRO's top and it will not tear.
Dan Morissette
'85 Guards Red Targa 911
My Owners Gallery Page
Non illegitimi carborundum
Old 02-02-2004, 08:26 AM
Senior Member
Early_S_Man's Avatar
Porsche Crest
Mark,
Is the tear accessible from underneath when the top is released from the hooks and clips ... and ready to fold? If so, I would recommend glueing a patch underneath of at least 4" x 4" dimensions [6" x 6" or larger would be preferable] of similar-weight vinyl with 3M Weatherstripping Cement #8011 -- the black kind, not the yellow! Let the cement set for at least four hours with the frame in the relaxed state ... with all bubbles or wrinkles worked out and without tension on the material. You will know the patch is successful if when fully tensioned, the tear doesn't try to spread open or open up ... and if it doesn't lengthen after a week's exposure to the elements in normal use!
Good luck!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-02-2004, 11:10 AM
Unfortunately, the tear is about dead center in the middle of the top, so it's not easily accessible. I honestly don't mind driving the car with an ugly patch on it for a couple of months until we get some warmer weather in which to re-cover the top, so whatever I do will probably be from the outside anyway.
Stopped by Lowes yesterday. They had nothing to repair vinyl with. At least their customer (dis)service people had no clue. I looked around and found nothing.
Mark Szabo
Old 02-03-2004, 06:52 AM
Mark,
I'd second Warren's suggestion on the 3M Black Weatherstripping Cement. I had the same problem as you have and it worked well and almost blended perfectly as to color. If the slit is large enough you might be able to fold a patch in half and gently slide it inside the top under the skin and then apply it from inside. Drop a little glob of cement inside on the patch and then press the top skin down on it. Finish with a thin coat of cement on the outside of the slit. If you can't get the patch inside just a decent application of the Black cement should hold you for quite a while.
Dan O
84' 3.2 Targa
Old 02-03-2004, 09:32 AM
ruf-porsche's Avatar
I recover my top last year and patching the cut from under the top is the way to go.
The "Headliner is not that hard to remove (not unless some PO went and contacted the entire headliner to the vinyly top). Even if you remove the headliner comepletely and patch from underneath, only you will know that there is no headliner and a patch under the vinyl top.
Patch it from above and everyone will know that the top has a patch (no concurse points).
Old 02-03-2004, 11:20 AM
Install one of my hardtops
Jerry
Old 02-03-2004, 11:25 AM
Virginia Rocks!
VaSteve's Avatar
Here's mine. The PO did this so I'm not sure what it is. I hope to recover it this summer.
Closeup:
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 02-03-2004, 11:33 AM
Virginia Rocks!
VaSteve's Avatar
Old 02-03-2004, 11:39 AM
steve911's Avatar
Mark--
I have some leftover vinyl that I used to redo the rear deck in my Targa last year. I don't know how well it would stand up to outdoors, but its yours for the taking if you're interested.
PM or email if you'd like it.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 02-03-2004, 11:43 AM
Thanks Steve! Look for the PM.
Mark Szabo
Old 02-03-2004, 12:09 PM
