-   -   Help opening monotronic for chip change (http://forums.pelicanparts.com/porsche-911-technical-forum/146862-help-opening-monotronic-chip-change.html)
lvle1416 02-02-2004 04:43 PM
I took off the lid on the monotronic on my 84 targa to change the chip. I took a small screwdriver to the black plastic screws that hold the boards together but there was no movement in the screws (located over the wire ribbon). I read the instructions but what do I do if the pieces holding the board together won't turn?
kepperly 02-02-2004 04:58 PM
lvle1416,
on my 87 carrera the two boards are held bye snap posts!
they snap together and pop apart. Warning are you prepared to solder in a new chip. On older Carreras they soldered in the chip and you have to remove it and replace it with a solder in socket
and possibly a zero force socket. If you are not very experienced in Boards do not do it yourself or you will be buying a new DME.
Please take it to someone that really knows what they are doing
and don,t solder in the new one even though thats how Porsche did it, What if Steve Wong makes further advances !!!!
Keith Epperly 87 slant nose turbo look Carrera cabriolet
don,t do it
I thought I could on my wifes civic ex (used board for it only $200.00 installed)
NY65912 02-02-2004 06:43 PM
I did my chip in 45 min....out, open, change, close, in, on my '85. You should have another pair of hands...to hold the bottom half of the board and pull on the top half as you insert the screwdriver into the posts and twist. You do have to exert substantial force. My chip was pull out (carefully) and pop in (carefully).
Good Luck
CrossT 02-02-2004 06:48 PM
The place to insert the screwdriver is in between the boards. Then while lightly twisting the snaps you need to pull the boards apart. Like kepperly said, the 84s may well be soldered. I suggest you call Steve Wong, for pointers. He's the DME 'samurai'.
todd
86 Coupe
stomachmonkey 02-02-2004 06:54 PM
My 84 is not soldered.
Scott
Lucky 02-02-2004 07:00 PM
Here's a step-by-step guide with pictures... should help you visualize what people are telling you.
http://www.dorkiphus.com/porsche/viewtopic.php?t=918
Silveresrty911S 02-02-2004 08:18 PM
My '84 wasn't soldered either, Wong chip went in smoothly.
Take your time and don't force it, make sure you get all the pins in when re-inserting the new chip or she'll run like crap" ask me how I know" :eek:
ischmitz 02-02-2004 11:10 PM
Here is another step-by-step. You can click on the images to enlarge.
http://sswl.di.com/~ingo/installation.htm
Cheers,
Ingo
ChrisBennet 02-03-2004 07:38 AM
Cheers,
Ingo
Note that ischmitz's (excellent) directions are for a 3.6 DME. The 3.2 procedure is different.
-Chris
lvle1416 02-03-2004 08:14 AM
Thanks for info. I didn't realize that I had to put the screwdriver between the boards--very helpful
This forum has helped me many times to keep my 84 getting better.
Wil Ferch 02-03-2004 08:21 AM
I wouldn't put ANY screwdriver directly between the boards..only the posts, and the small "tabs" on the boards.
---Wil Ferch
lvle1416 02-03-2004 06:03 PM
Opps-I was thinking of the putting the screwdriver into the posts between the boards to free the boards- not directly on the boards.
ChrisBennet 02-03-2004 06:10 PM
I put the screwdriver into the slot in the post to pry the fingers apart while simultaneously applying finger pressure to seperate the boards.
-Chris
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
