Phew! I suck at driving the 911's. I keep spinning at about 140kph resulting in a crumpled car by the end. I gonna get whipped tonight!
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
SCWDP- Shock and Awe Dept
Can anybody try to connect to me right now? I'll wait for a response here then starter her up. IP 198.81.26.14
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
The '73 RS and the '78 3.3 Turbo are really, really hard to drive compared to the others. It helps tons if you go through both the factory driver stuff (teaches car control) and the evolution mode (you work your way up to faster stuff). They were really important to me getting better. Also, I used to drive with the keyboard, but to get really good you need a wheel and pedals. With the keyboard you have to learn to throw the cars into slides through the corners since the only steering that you have is straight or full lock.
Stahlwerks.com
I can try to hook up, fire it up.
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
Cool! Give me 1 min.
Stahlwerks.com
Nope, nada
Stahlwerks.com
wanna try mine? 66.26.20.105
Damn! OK, I checked the IP on the above link 198.81.26.14 and at the upper right hand corner of the game it says 169.254.250.241, same one as last night which, I assume is the ISP router IP.
Any other ideas?
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue Last edited by surflvr911sc; 02-04-2004 at 05:22 PM.. |
I'll try!
it might help to setup max downforce on the rear, max the suspension stiffness, max suspension travel (weird huh?) & i think use about 50% front toe in... I haven't played for ages, but from memory that setup worked better for most cars.
Can't do it.
Stahlwerks.com
bummer, probably not getting past my router firewall. Don't know enough to open it up.
Doh.... I cant even install the v3.5 patch. comes up with this
FILE_load - unable to open file install.txt [FILE=\real\cmn\hlsfile.c,LINE=218] Any ideas? Got the patch from http://www.nd4spdworld.com/?section=util&v=5
Shoot me an email and I'll send it to you.
Senior Member
is anyone up and serving right now, would like to test and come back later
78 Euro 911sc Targa 03 Hayden SCWDP |
I can bring it up at 198.81.26.14, but so far I'm unsuccessful at p2p.
Thanks Ryan. I just got it from the link that, you posted, and I missed, earlier in the thread..
When do we kick off?
I should have changed that! That link sucks, let me email a different one to you.
Senior Member
ryan email me the file too as I not sure I have it sidak @vnet.net (remove the space)
