GrindingGears's Avatar
Question Euro ride height for an SC?
What are the measurements?
Philip
83 SC (gone) // 72 T (gone)
Old 02-03-2004, 10:41 AM
Hey, Philip
25" rear 25.5" front measured to the high point of the fender lip.
This gives a slight nose down rake.
MY SC is lower, I think it's about 23.8 rear and 24.3 front. And maybe to low for driver?
It was good seeing you at Dunkles.
Check out my # of posts
Old 02-03-2004, 11:22 AM
Thanks Bob, why do you say "maybe to low for driver?" ?
EDIT: 911 posts, sweet! Now you've gotta retire that name, keep it real!
Old 02-03-2004, 11:30 AM
I'm off the hook.....
Mine was the same as Bob's for a while. Every freeway junction, every bump was transmitted to the butt. Driveways, dips meant a drag on the skid plate. This pic doesn't show the rake because the RR wheel is sitting in a drain. Yes, that 'other' red car is Wayne's.
Was uncomfortable. Mine is between the two now, still with a slight nose down rake.
Old 02-03-2004, 11:44 AM
To late now, This is 913 already.
Regarding to low, I guess it all depends on were a guy might have to drive. I have to watch driveways and grade changes more closely than when I was an 1" higher, but I don't mind.
If you have a front spoiler you do need the tow hook re- enforcers IMO so they strike before the lip does at the lower hights.
That is correct, I have the reinforce plates. They hit first. At the lower heights, there just isn't enough suspension travel to get a decent ride. The ride at high speed IS better, but even with all the long distance I do, still didn't justify the around town discomfort.
No, I don't sing. Based there for too long.
Old 02-03-2004, 11:51 AM
jyl jyl is offline
jyl's Avatar
At what front ride height do people feel they need the RSR struts?
1989 3.2 Carrera coupe
1988 Westy Vanagon, Zetec conversion
Really want to find a clean E28 . . .
Old 02-03-2004, 11:55 AM
Originally posted by singpilot
Sing, this is the first time i've seen a picture of your pcar. do you still cruise around the south bay from time to time? i'll keep an eye out for you.
Old 02-03-2004, 12:36 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
914 Bob, are you trying to tell us something?
Nice meeting you the other day Philip. My car is at 25" front 24.5" rear, I think it's about perfect, But I do like like them as low as you can get it.
If you go too low tire rub and bump steer become problems, and the rack spacers are not a great idea imo.
Edit: had the heights reversed.
Old 02-03-2004, 12:54 PM
Formerly bb80sc
Vipergrün's Avatar
I have heard that anything around 23.5" rear and 24.0 front *could* make a candidate for the RSR struts. However, there are three more things you need to address when lowering your car;
1. remove the 10mm thick washer/spacer between the top of the strut and the strut housing.
2. cut down the rubber bump stops on both the front and rears. This will keep the shocks from bottoming out too soon and loading things up.
3. address the bump-steer with either steering rack spacers (which Ryan mentioned), or go with a bump steer kit.
I need to get my car back down a bit.....I decided to start removing stuff AFTER my corner balance.....duh..
-b
Cheers
-Brad
Porsche-less
2017 Mazda CX5
Old 02-03-2004, 01:26 PM
I agree the precision bump steer kit would be the way to go with a 911 lowered below the average euro height. I just have the spacers.
Weltmeister makes one. I don't think I've heard any comments on them though ?
Shocks that are the right length would be another consideration, or at minimum shorten the bump stops in the shocks.
Ryan, Did you put your visors on ? Mine are in plan check
Old 02-03-2004, 01:28 PM
Yes, I finally got my digicam working again. I am usually in the SouthBay when in SoCal. I sometimes stay there in the marina on my way to or from the Vegas home. As far as I know, I am the only red 911 with Nevada plates I have seen.
This is my other ride (also red with Nevada plates) parked under my other ride (white with no plates).
Old 02-03-2004, 01:29 PM
SRISER's Avatar
Front is 25", rear is 24.5". Kind of a bad pic...
Sam
'02 996 TT
'07 Audi S4 Avant
'88 Carrera (Sold)
Old 02-03-2004, 01:31 PM
SRISER's Avatar
This is my other ride (also red with Nevada plates) parked alongside my other ride (no plates).
944's with the Fuchs look soooo good. I had a 944 and thought it was a blast.
Sam
'02 996 TT
'07 Audi S4 Avant
'88 Carrera (Sold)
Old 02-03-2004, 01:32 PM
SRISER,
Like your car too. I just did the drilled rotors and brake cooling kit for the 911 too. Great looking car you have!
Old 02-03-2004, 01:35 PM
SRISER's Avatar
Hey thanks. I did cross-drilled front and rear. Not much difference in terms of stopping power...just mainly for looks anyway. Slightly better in the wet. I just put the 7J's on , turbo tie rods and had it lowered about two weeks ago. Now comes the replacement struts and shocks.
Does this project ever end? We all know the answer to that!
Sam
'02 996 TT
'07 Audi S4 Avant
'88 Carrera (Sold)
Old 02-03-2004, 04:42 PM
Mine had the bump-steer spacers under (above) the rack when I got it, when it was so low. When I took it up to Euro, the spacers came out. Now that I am about halfway to US Spec, I will get little wheel jumps when the front end is light. Just enuf to 'talk to ya'.
Same same, I think the braking is the same with the drilled rotors, and yes maybe slightly better in the heavy wet (never rains in SoCal, yeah, right), but are better when hot. Not better braking, but quicker to cool.
I like the look as well. I keep an eye out for the cracks that everyone says might happen. I am always falling victim to the "While you are in there" bug.
I did the rotors, bearings, pads and TRE's as well on the 944. Didn't do the brake cooling mod on it, it doesn't get pushed as hard as the 911.
Old 02-03-2004, 05:17 PM
