Sway Bars
Ok...I have a choice to either stick with the stock under body front sway bar on the Carrera suspension that I purchased for my early car or use a through the body bar the car orginally was designed for. If you had a choice, which option would you spring for?
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine '74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans. '80 924 AAN 5-Cyl Swap - Team UBoot Rennwerks |
Vinyl guru ask 4 a quote
The thru body one adjustable....the underbody one is not. Choice is clear to me....
1983 cab. 3,6 lots of other stuff. Now the daily driver. 2012 Mercedes ML 350 Parked. |
what mike said. thru body all the way.
Ash
'70 911E tangerine coupe (Ash's car) '71 911T viper green targa (Trac's car) - Sold |
Thread Tools | |
Rate This Thread | |
