Automotive Monomaniac
Emission's Avatar
Care and life of the temporary spare?
I've been wondering about the service life of the collapsible spare. I don't think mine has ever been removed, or tested, in nearly two decades.
If I pull it, and inflate it, will it collapse back down easily, or do I have to pull the valve stem?
How long are they good for? I don't think rubber ages well... is it still safe at 60 mph?
I also just noticed that the collapsible spare is never to be used on the rear. If you blow a back tire, you should put a good FRONT tire on the back, then the spare in place of the missing front. Interesting - and a lot of work on the side of the highway.
Many of you ditch the spare/jack for a can of fix-a-flat. It sounds appealing...
2012 - Porsche Boxster Spyder 6MT / 2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 2018 - Volkswagen GTI 6MT
Old 02-03-2004, 03:10 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Or AAA card, but I do throw it in for long trips.
Since I don't normally run w/ mine I traded my never used spare for my dad's probably used once spare. I can't see how you could get the spare to fully collapse unless you had some kind of special vacuum setup for it.
I tried ratcheting straps to get it collapse, no way, so from my experience I wouldn't suggest 'testing' it out.
Old 02-03-2004, 03:19 PM
Friend of Warren
Despite what Ryan says, yes it will air up and collapse into the form it is presently in. Mine probably wasn't aired up in 16 years prior to me airing it up and it collapsed just fine. I now air mine up every six months just to make sure it works.
Kurt V
Old 02-03-2004, 03:25 PM
Oh great, make a liar out of me! Do you have a trick, or is mine just a POS?
I think my dad screwed me! WWTD?
Old 02-03-2004, 03:27 PM
I used mine (from the looks of it for its first time ever) on the back of my 930 last week. no problems at 50mph. i went pretty easy on (370hp) throttle though..
Cheers - Ryan
ps: it looks well funky in the rear wheel well of a 930
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 02-03-2004, 03:59 PM
You should NEVER use the inflatable spare on the back...
The diameter is different than OEM , and you're putting a lot of stress on the differential action of the transaxle..especially if you have limited slip.
The drill is to put any front tire on the back where it's needed to replace a flat...and then put the spare on the newly-vacant front.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-04-2004, 07:21 AM
Rouxzy's Avatar
I just tested my spare, which is over 27 years old. Inflated fine and collapsed back into shape. Cleaned it and put back. I hope I never have to use it.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 02-04-2004, 07:44 AM
Senior Member
Superman's Avatar
I don't care whether my spare is in good shape or not. I carry two cans of Fix-A-Flat, a VISA card and I should also join AA. And perhaps AAA as well.
Old 02-04-2004, 07:54 AM
When I was at Road Atlanta Last month for a DE, the guy inspecting my car told me the spare should be left in place because it is part of the crumple design in a crash. I don't know if that is true or not, but it kinda makes sense. any thoughts one way or the other? Craig
80SC
Old 02-04-2004, 09:10 AM
Vinyl pimp
Joe Bob's Avatar
The spare in my opinion....is worth only the space it uses for protection if I ever rear end someone. I HAVE, out of curiosity aired it up and dumped it water to look for leaks, but never plan on using it.
AAA, tire plug kits are a standard must have for MY travel. If I REALLY REALLY had to I would use it....but it would be my dead last choice.
Old 02-04-2004, 09:19 AM
Porsche Less Member
k9handler's Avatar
Send a message via Yahoo to k9handler
I have never used it...but I did air it up just to see what it looked like, the deflated and back in it's place. The only thing I would like to do is mount it on a Fuchs.
H.D. Smith
2018 Ram Power Wagon "Crystal Black"
2016 Dodge Charger SRT "Go Mango"
2019 Can Am Renegade 1000R XC
Old 02-04-2004, 09:27 AM
joecrum's Avatar
I've never pulled mine out and inflated it (my spare, that is) so I've never really looked at it. How does it allow the diameter to increase when inflated? Does the tread surface stretch? I'd go look but I'd have to dig my way to the garage.
joe
>82 3.0 SC
>01 Audi S4 Avant
Old 02-04-2004, 09:50 AM
MuffinMan's Avatar
Everything I've read indicates that the spare is part of the crash protection system designed by Porsche. Keep this in mind when running without it. If others have heard otherwise, I'd be interested to hear what you've learned.
Rob Fusi
77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s |
GTC Motorsports
Old 02-04-2004, 10:45 AM
Author of "101 Projects"
Wayne 962's Avatar
I have heard conflicting reports on this myself. I have come to this conclusion: There were a few different types of spares made over the years (collapsable). Some will collapse easily, and other just will not. It's best to not mess with it...
-Wayne
Old 02-04-2004, 11:38 AM
Friend of Warren
-Wayne
Have to disagree with you here Wayne, I would rather take the chance of testing the spare and finding out it will not collapse as opposed to not testing it and then finding out it doesn't work!
Kurt V
Old 02-04-2004, 11:51 AM
I've heard this too..about the spare being part of the designed-in safety program of the car..
IMHO...I believe that if this were true...it would apply to the normal spare for the smaller gas tank. Let's think real hard how a collapsed rubber-band of tire over a steel drum affords any protection. Now, a full size spare filled with 30 psi of air..and a sidewall height of maybe 3-4" ( make that 6-8" if you count top and bottom )...then you may have something.
---Wil Ferch
Wil Ferch
Old 02-04-2004, 12:14 PM
Wayne 962's Avatar
So if it expands, and then doesn't collapse, then you have to buy a new one? Then you have to test that one, won't collapse, etc...
Leave the spare alone, make sure you carry an air compressor (to inflate it), and also have your AAA card handy...
-Wayne
Old 02-04-2004, 12:18 PM
Emission's Avatar
Can someone post a pic of one that DOES collapse? I want to test mine (just for kicks - and piece of mind) and I want to make sure I have one with will go back...
Old 02-04-2004, 01:36 PM
