78sc's Avatar
brake light fuse burning
Hi all,
Figured I'd ask folks if they'd ever experienced this before I go digging around in my wiring. Out of the blue one day, I noticed I had no brake lights...found burned out fuse and replaced. Drive car, and surprise, no brake lights again (the same burned fuse). Found out that whenever I put the gear shifter in reverse, the fuse for the brake light will burn out. I guess the first thing I would suspect is the backup light switch? Anyone else have this problem before?
Thanks,
Phil
Phil
1978 911 SC
Old 02-10-2004, 12:46 PM
Heck, I’m only 5 not 71!
targa80's Avatar
sounds like it could be anything in the back up light circuit.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 02-10-2004, 02:33 PM
Has the engine/transmission been out recently possibly resulting in severed/pinched wires leading to the back up light switch? Jim
Old 02-10-2004, 04:06 PM
78sc's Avatar
No, engine/trans has been planted in there since I bought it 9 months ago. (my first Porsche and I LOVE IT!!) During a drive one day, it just burned the fuse when transmission was put in reverse.
I have the 101 projects book and figured I'd start with the back up light switch and test backwards from there. It's got to be something mechanically related to transmission lever/linkage.
Phil
Phil
1978 911 SC
Old 02-10-2004, 04:25 PM
check the wires on your backup light switch
Old 02-10-2004, 05:49 PM
Send a message via AIM to fintstone
Since I don't have a schematic of your year, I am not sure if the backup and brakelights come off the same fuse. If they do, then obviously the problem is in the backup light circuit. I suspect they come off different fuses, so if your backup lights work and not your brakelights, I would not check the backup switch. I would first check the brakelight switch for a bare wire that is shorting...I assume you put your foot on the brake when you go into reverse. That might be just enough to ground a bare wire.
If that is not the cause, I would ckeck the shift linkage to ensure that the brakelight wire has not been run such that it is pinched when in reverse.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 02-10-2004, 10:14 PM
