-   -   3.2 Starting Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/147187-3-2-starting-problem.html)
PCA7GGR 02-04-2004 06:19 PM
Have any of you had the follow problem with a 3.2 Carrera:
The engine cranks but won't start unless you quickly cycle the key to the start position - momentarily hit the start position. If you cyle the starter quicly, the engine fires and runs smoothly. The reference sensors have been changed as have the cap, rotor, spark plugs, DME abd DME relay.
