-   -   Do I need gasket sealer on output seals for my 915? (http://forums.pelicanparts.com/porsche-911-technical-forum/147217-do-i-need-gasket-sealer-output-seals-my-915-a.html)
chrisp 02-05-2004 05:25 AM
I put new seals in last night and realized that I may have needed to put gasket sealer in there. Is this a mandatory or optional? I certainly don't want them to leak later so if I need to remove them and buy new ones I will but if we think they'll be fine dry then I will keep them as is.
There were a bear to get out. Much harder than the flywheel and pulley seals. A much tighter installation too.
ChrisBennet 02-05-2004 06:22 AM
Unless you scratched/gouged the outer sealing surface getting the old ones out, dry should be fine.
-Chris
